383 problems- rough running
Old Sep 27, 2005 | 07:51 PM
MikeC's Avatar
MikeC
Default 383 problems- rough running
Here's the details guys,
383, Sportsman 2 heads, comp XE274 cam, Performer RPM intake, holley 750 vac secondary carb, MSD 6a. The engine is brand new except the carb( reman unit), and MSD was used. Its running around 10.5:1 compression
When first started up, the engine ran great, idled as good as it can with that cam. I tuned it up(leaned out mixture turned down idle speed screw) and adjusted timing(16 initial, ~36 in by 2500) and am running manifold vacuum. I ran a steady 12 inches of vacuum.
Now I have a backfire out the exhaust when I crack the throttle at 2700 RPMwhen its under load (no backfire when revving it in the driveway). I checked the vacuum its jumping from 5-15 inches with a very lopey idle. I checked fuel pressure and its 6 PSI steady as a rock The float level looks to be perfect. When running in the garage it smells extremely rich, the plugs are a dark brown.
I am thinking it may be the power valve is not the right one for the engine. What do you guys think?
Old Sep 27, 2005 | 08:17 PM
LFZ's Avatar
LFZ
i had the same problem...and still have some of the same problems. I had a backfire thru the carb though, and it was the PV..i changed it..it solved my backfiring, but still the engine runs rough with no steady vacuum. Sorry i'm in your boat too.
Old Sep 27, 2005 | 09:17 PM
big_G's Avatar
big_G
I don't think a XE274 should have a very lopy idle, unless your idle speed is too low...Should be a nice lope, but not aggressive...maybe a lifter set a little tight?
Old Sep 27, 2005 | 09:20 PM
Brettmc's Avatar
Brettmc
Sounds like a lean misfire. Try bvacking out the idle mix screws 1/8-1/4 turn.
Also, if the carb is rich at idle, you can't get rid of that by using the idle mix screws. They only control the volume of the mixture, not the characteristics of the emulsion, ie the actual mix of gas and air. To change the emulsion you need to alter either the amount of air or gas introduced. With a plain ol Holley 750 VS, you will need to put some thin wires in the idle circuit. I've got a pic at work of the metering block and where to put the wires. I can send it to you if you need it.
Brett
Old Sep 27, 2005 | 10:28 PM
vette64772's Avatar
vette64772
Try backing off the initial timing. My 383 is set to 10 deg initial and 34 total and runs very strong..........
Old Sep 28, 2005 | 10:42 AM
Highhat's Avatar
Highhat
To jump in on the timing, mine is set at locked out 36 and runs great.
Old Sep 28, 2005 | 11:57 PM
glen242's Avatar
glen242
What does this mean? How do you lock out at 36*? Not familiar with the "lock out" term. Do you mean the most centrifugal + initial you get is 36* at some rpm, hopefully under 3000? Are you using a vacuum advance can?
Old Sep 29, 2005 | 11:16 AM
Highhat's Avatar
Highhat
Sorry. I replaced the iginition with MSD ignition, and you can set and lock out the advance in the distributor.
To 383 problems- rough running
