Vibration question
Old Sep 27, 2005 | 08:39 PM
toyvet1's Avatar
toyvet1
Default Vibration question
I have a slight vibration coming from the engine I think. At highway speeds the car has a vibration but if you put the car in nueteral the vibratuion goes away. Leave it in nueteral and rev the engine no vibration. What would cause vibration only under load....
Old Sep 27, 2005 | 08:41 PM
PhotoVette1's Avatar
PhotoVette1
Drive shaft U-joint going bad. For sure. For sure.
Real easy to replace.
Old Sep 28, 2005 | 08:41 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Out of ballance drive shaft....auto or standard? if it's an automatic it does not hurt to check the torque converter bolts.
Old Sep 28, 2005 | 12:36 PM
C3nMe's Avatar
C3nMe
I also have this problem ...and it's most notable under heavy accelleration -- but it almost totally disappears under cruising speeds. I just replaced all the U-joints, so I am a little hesitant to think those ...
Any way to confirm drive shaft or a transverse shaft is out of balance?
Brian
Old Sep 28, 2005 | 10:58 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
don't forget a bad fan clutch will cause vibrations
Old Sep 28, 2005 | 11:03 PM
dennis's Avatar
dennis
Where is the effect of the bad fan clutch felt? Front , back?
Old Sep 28, 2005 | 11:30 PM
toyvet1's Avatar
toyvet1
79 four speed car, new u joints, electric fans. drive shaft and half shaft balanced last summer??????
To Vibration question
