Cooland Color
Old Sep 28, 2005 | 11:09 PM
JonnHeather's Avatar
JonnHeather
Default Cooland Color
I have new motor with aluminum heads and a new Aluminum radiator. Do I go with the green coolant or the newer Dex Cool extended orange coolant? I have heard the new coolant is more corrosive than the old coolant, but the new coolant is suppose to be better with aluminum? Which one will protect against corrosion better?
Old Sep 28, 2005 | 11:11 PM
David Ey's Avatar
David Ey
DO NOT USE THE EXTENDED LIFE COOLANT.
Use the old tried and true antifreese and distilled water 50/50
Old Oct 2, 2005 | 01:00 AM
JonnHeather
Is any brand any better than any others? Why doesn't GM use the green stuff any more?
Old Oct 2, 2005 | 01:05 AM
David Ey's Avatar
David Ey
well, now I see the others have gone to a long life formula now so I guess I dont know
I have heard of head gasket problems with the red coolant, besides, whose gonna leave it in more than a couple of years anyway?
Just make sure you reduce it with distilled water rather than tap water.
Used to be there was only one chem plant producing it.....likely still that way....prestone,zerex,o'reileys,wallmart ''''all the same. You can also get it pre-deluted .
Old Oct 2, 2005 | 02:40 AM
BB wowbagger's Avatar
BB wowbagger
Dont mix Red and Blue/Green antifreeze. It will combine into a nice sludge and glogg everything.
Old Oct 2, 2005 | 09:26 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Maybe this link will help with your questions.
http://silverstone.fortunecity.com/f...64/coolant.htm
Old Oct 2, 2005 | 10:46 AM
David Ey's Avatar
David Ey
Yeah, that helps all right. It shows another example of 'they should not mess with something that works'. Now a simple cheap product and maintenance procedure can end up costing hundreds if not thousands of dollars. Does anybody really think the auto manufactors change anything to make their product last longer? How many cars do you think this little change will sell over time?
I want some plain old Prestone to put in my new motor. It served me well for____ years. Who knows whats in that yellow jug now.
Old Oct 2, 2005 | 11:30 AM
ltlevil's Avatar
ltlevil
Couldn't open the above link, but what you need to keep in mind is getting a coolant that is compatible with aluminum components. I have seen aluminum heads/intakes come through the shop that I had to weld up water jackets on and then resurface because the were ate up from either wrong antifreeze or not running any antifreeze.
Old Oct 2, 2005 | 11:42 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
go with the green.. if you have a leak with the orange, it corrodes very fast!
Old Oct 2, 2005 | 09:23 PM
JonnHeather
What does everyone think of the coolant additives, such as the royal purple and the ice products?
To Cooland Color
