Is it common to have to trim the fender of a 1977 to fit 255/60R15 BFGoodrich Radial TA to allow for clearance? I just got new rally wheels with the above mentioned tire and my tires rub slightly on the rear lower front fender when I turn the wheel. Is this typical and has anyone else had this problem?
I guess they are all slightly different.but, I have 255/60/15 on front and 275/60/15 on rear mounted on orig 8 inch alum wheels and have no problem.. BFG TA's
However, when I spin the rubber off the rear I think I'll put the fronts on back and replace them with 235's on front.
Yup, had the same issues with my 77, I took the easier route and returned the 255-60-15 fronts and went for some 225-70-15. Looks better now in my opinion, narrow in front and fat in back. No issues with 255-60-15 in back. Brand same, BFGoodrich Radial T/A.
Some 1978 and 1979 cars had the fenders trimmed when they came from the factrory, just looked at a friend's '78 - they did not do a very clean job, looks like a 4" angle grinder massage.... ... and yes, that car is all original, bubba hasn't touched it....
