Heater core removal
Old Sep 29, 2005 | 12:00 AM
jack76's Avatar
jack76
6th Gear
Default Heater core removal
I'm trying to replace / repair the core in my 76. I've torn the dash apart and loosened the heater housing on the passanger side, but the housing still seems to stuck on something I can't see (loose but won't pull out). Do you need to do something from the engine / hood compartment (I did find one bolt to loosen...still not out.........uggggggggh!!! Ideas?? (cables already released......)
Thanx! Jack 76
Old Sep 29, 2005 | 12:19 AM
jyounane's Avatar
jyounane
Default one more bolt
Others can verify...but I recall you need to remove the blower box assy from firewall in engine bay to get to at least one bolt/screw holding the heater housing. Was it an a/c car?
Old Sep 29, 2005 | 12:25 AM
jack76's Avatar
jack76
6th Gear
Yep has A/C. Blower box looks like some tight work in the engine compartment. Thanx....
Old Sep 29, 2005 | 12:29 AM
Cali,68,L-79's Avatar
Cali,68,L-79
Just went thru this. Hope this helps http://forums.corvetteforum.com/show....php?t=1174120
Old Sep 29, 2005 | 12:37 AM
jyounane's Avatar
jyounane
Default A/c nuts on studs from heater box
You might check to see if a couple of the studs on the heater box go through the firewall and blower assembly. Perhaps removing the nuts from these studs will be enough to free the heater assmbly without removing blower assembly.
I've got a system from a 77 in the shop...I could take a look if you like.
Good luck,
Joe
Old Sep 29, 2005 | 12:42 AM
jack76's Avatar
jack76
6th Gear
Thanks...pictures help!!!
Old Sep 29, 2005 | 12:43 AM
jack76's Avatar
jack76
6th Gear
Good idea on the studs...will check this out in the a.m.
Thanx
jyounane's Avatar
jyounane
Default Stud top left corner
OK,
Had a look at my 77 heater box....has stud on top left corner when viewed from inside the car....find corresponding nut on top or side of blower assembly on firewall to remove.
Can photograph if you send me an email address.
Cheers,
Joe
Old Sep 29, 2005 | 12:45 AM
jack76's Avatar
jack76
6th Gear
thanks..email to jack@jmicorp.com.
Old Sep 29, 2005 | 12:58 AM
jyounane's Avatar
jyounane
Default Photo Sent!
Should be easy now
To Heater core removal
