Too much fuel pressure
Been having these bizarre fuel pressure problems, can't think I am the only one to ever experience this. Trying to keep this short of a novel but here goes;
496BB.
Edelbrock performance 130GPH mechanical pump.
1/2" fuel lines.
Matching edelbrock regulator set to 6lbs.
New Holley HP series 950.
Piece of garbage Holley mech pressure guage between regulator and Holley.
Good hi volume large cannister filter before pump.
So it goes like this, fuel would stream out of the vents on the carb when I would reach 3500RPM under load. As I could never see it I thought the problem was a vibrating centerforce, it wasn't. Turning the regulator all the way down to 3lbs problem decreased but still significant. Hooked up return line which helped a lot but would still happen but only on sudden deceleration with the pressure cranked down as far as possible. Regulator diaphragm finally ruptured. Disgusted with this I did some research to find the mallory regulator was designed for an electric pump, also the pump for whatever reason according to Edelbrock was not designed to run with a return line? Why it would matter I can't imagine, however, for me this is a good thing as the return leaked by the tank anyways. So, replaced the mallory with the matching (expensive) regulator for the pump, Improved again but would still intermittently flood even at idle. Very dangerous condition indeed given the volume of fuel that would stream from the vents. Car ran great for a couple days then suddenly started barfing fuel everywhere again, stranded on the side of the road with nothing helping, no stuck floats, pressure cranked down etc It just would not stop overflowing. Took it to the local performance carb shop who tell me the regulator is bad although they haven't taken it apart yet but observed pressure readings in the TEENS (randomly).
So..... How the heck is this possible? I have not yet replaced the pump but it is just a diaphragm? Could it vary like that and create these problems. I would understand low pressure problems but high? I am also disgusted with myself that I had to resign myself to just taking the car someplace. Just concerened that I am replacing yet another regulator that is the symptom and not the cause.
Any thoughts or similar experiences greatly appreciated!
-Andre
Also, why do you need so much fuel flow?
BigBlockk
Later.....
BigBlockk
Later.....
It could also be dirt in the fuel line causing the needle not to close fully. Needles and seats are easy to remove and blow out.
I don't believe in the cheap regulators but alot of people have had no problems with them.
I replaced both floats as one looked bent to me but it made no difference. Set the float levels even trying them very low with no avail. Cleaned out the float needles and tried a different one to see if it would help. Nothing does. As I mentioned before the only thing I haven't replaced is the pump but it just makes no sense to me that a deffective pump would create pressures so high that two what should have been quality regulators could not control it.
It is a big carb but it is a thirsty beast. 496 BB with roller cam, Brodex RR heads with 500HP at the rear wheels. Irony is that when it is behaving which it often does it is actually a little lean at WOT. I'm concerened that with a stock pump I just won't provide enough fuel volume. Perhaps I'm just going to have to go electric.
-A
Engine builder just put together an engine very similar in configuration to mine which It ran 585HP on the engine Dyno. Can anyone tell me what fuel volume is needed for this amount of HP? In other words could a stock mechanical pump keep pace with it's needs? I really don't race the car but do occasionally attend track events and hope to do more in the future.
-A
-A
The BSFC (break specific fuel consumption) for performance engines of our vintage is about .5lbs of gasoline per HP per hour. Now let's see... gasoline weights about 6 pounds per gallon and we got a fuel flow of 130gph. So each gallon will..... I always hated math. So each gallon will produce about 12 HP per hour. Does that sound right? Now we multiply that by 130gph and get......SHAZAM, 1560 rompin' stopin' horsey powers. JUST DAMN DUDE!!!
Wate a minute! I'm a little disapointed in you young man. You're only pumping a little over 2 1/2 times the fuel the engine actually needs. You go to bed without supper!
BigBlockk
Later.....
Just think of what a 427 L88 or a 454 LS7 is comprised of. 12.5-1 and 12.25-1 in the latter because of a copper head gasket as opposed to a composition used in the LS7. Wild camshafts in both and properly tuned are good for nearly 600HP in box stock configuration with the addition of a good set of headers. My point here is that they use a stock mechanical pump at around 6-7 psi with 3/8 lines and never lean out. Take a look at the fuel line inlet nuts on your carb. The actual hole in them is only about a 1/4 " feeding the carburator. I would say without knowing much more about your set up is that your trying to push too much fuel and blowing the needle and seats. Fuel in the oil is often a result and much worse than a lean condition. See what the plugs tell you. You can get a lot of information by reading the plugs to tell you whats happening in the cylinders. You have obviously gone to considerable expense with this engine and want it right so you can go out and have fun with it. Get an opinion from a local racer similarly situated {same engine} in your area and tell him what you have, most of them would be glad to help with a hands on fix. PS good luck
Thanks again for the advice.
Cheers
-A
SolidLT1 recommended it to me and he has been running it for awhile now.
Big-time fuel flow for big-time performance. Carter Competition Series Race Super mechanical fuel pumps deliver big-time fuel flow. Their free-flow output is 172 gph. Despite this high capacity, their compact size means that they often fit where other high-performance pumps won't. In addition, they're ''clockable,'' which allows rotation of the inlet and outlet. They have heat-treated, high-speed levers, plus -10 AN inlets and -8 AN outlets, with fittings included. With 7 to 8.5 psi operating pressure, no regulator is required.
Mine runs a steady 7PSI.
Cheers
-Andre
Not sure where you got your pump/regulator from but if from Jeg's or Summitt they are pretty good about refunds within the first year. Fortunatley I decided to keep all my parts boxes so I was able to return mine in the box. But if yours is defective they should refund or perhaps provide credit towards a replacement.
Have fun !
Usually run the cheapie 6lb Carter street pumps, keep up just fine, never once had a failure.
