door won't open
Old Sep 30, 2005 | 02:24 AM
MightyMickey's Avatar
MightyMickey
5th Gear
Default door won't open
Passenger door doesn't always open (80% failure rate) on my '72 Vette. This happens from inside and outside. Door panel is old and stiff, about to crack if not removed carefully. How do I remove panel so I can check locking mechanism? Thanks in advance! Mighty Mickey
Old Sep 30, 2005 | 05:48 PM
chris75stingray's Avatar
chris75stingray
there should be one screw at each corner . the two screws for the door pull. and then the lock **** is held on with a metal clip that is a pain.they have a special tool to remove it but you can use a little screwdriver.
Old Sep 30, 2005 | 07:34 PM
surfshark's Avatar
surfshark
If this helps on the door latch - I've replaced mine a couple of times. You can watch the linkage to see if it's binding or flexing and therefore not fully activating/(releasing) the latch mechanism. Sometimes a little grease helps, or merely tightening loose components in the door mechanism.
Old Sep 30, 2005 | 09:04 PM
1BAD80's Avatar
1BAD80
This may not be your problem, I have seen when the car is painted and not taped off, the paint scrapes off & builds up, holds it closed and unable to open.
To door won't open
