Motor Mount
Old Oct 1, 2005 | 01:47 PM
jac1502's Avatar
jac1502
Default Motor Mount
I have a broken driver side motor mount any tips or tricks to replace it easy. Any help would be great
Old Oct 1, 2005 | 03:48 PM
fl_rider's Avatar
fl_rider
Put a 2x4 on top of a floor jack (about 10 to 12 inches long).
Jack lightly on the drivers side of the oil pan and then pull the bolts and then replace the mount.
There are 3 bolts holding the mount to the block (9/16" socket) and one bolt going through the bottom of the mount and the frame ear. On mine one end is 5/8" and the other is 11/16".
You will have to loosen up or remove the power steering bracket while you are doing this.
The mount sandwiches in between the PS bracket and the block.
Old Oct 1, 2005 | 03:56 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Good tips!
Old Oct 2, 2005 | 09:38 AM
Fevre's Avatar
Fevre
I broke my driver side and replaced it with a poly one, the driver side sees almost all the torq which causes it to break.
Old Oct 2, 2005 | 11:37 AM
ltlevil's Avatar
ltlevil
Something I have done on some hot street cars was to run a solid mount on the drivers side and a rubber one on the pass side. This still lets the motor "flex" a little while the solid mount holds everything together. Just make sure that the mounts are the same "height" so the motor sits level.
Old Oct 2, 2005 | 04:42 PM
toyvet1's Avatar
toyvet1
What are the signs of a broken mount
Old Oct 2, 2005 | 04:46 PM
fl_rider's Avatar
fl_rider
Open the hood
Start the engine
If it's an automatic...
Step on the brake and put it in drive
Hold the brake and give it some throttle
If the mount is broken you will be watching the drivers side of the engine lift as you are applying throttle.
Old Oct 2, 2005 | 11:17 PM
toyvet1's Avatar
toyvet1
And on a four speed car you would??
Old Oct 3, 2005 | 07:22 AM
gator79's Avatar
gator79
first indication would be the fan rubbing the fan shroud on hard acell
Old Oct 3, 2005 | 09:38 PM
Rich80's Avatar
Rich80
Lift the hood. Start the engine. Set your idle up a little. Ease the clutch out with the brake on and you will see the engine pick up. Makes a God awlfull sqeal if she lifts too much. I didnt have any problem replacing mine and i am a Bubba! Good Luck..
Old Oct 3, 2005 | 09:56 PM
surfshark's Avatar
surfshark
That's pretty neat about the soid mount! I usually have chronic motor mount problems (replace every couple of years). I finally replaced the auto trans mount at the same time and that helped. I also have to raise my car slowly (in increments of inches) while I loosen the three motor mount bolts or install them.
Old Oct 4, 2005 | 12:43 PM
desi's Avatar
desi
Spend the money and buy the Energy Suspension part. Well worth the money.
The made in overseas crap has poor quality and does not fit. Ask me how I know this....
Old Oct 4, 2005 | 12:55 PM
jac1502's Avatar
jac1502
I jusy hope its not something i have to do every couple of years. Good thing my hood was off because my engine is moving a lot and my air cleaner barely clears as it is
To Motor Mount
