engine for the 75 pro street almost done
Old Oct 1, 2005 | 09:16 PM
panchop's Avatar
panchop
Default engine for the 75 pro street almost done
bottom end is done. mocked up the top end. need to get some more hardware for it. longer cylinder head studs, 12 point bolts for the manifold etc... then it's on to the frame.
Old Oct 1, 2005 | 09:28 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Holy smoke that's scary,nice job, you've been busy, specs ?
Old Oct 1, 2005 | 09:35 PM
JoeC427's Avatar
JoeC427
Old Oct 1, 2005 | 09:46 PM
fl_rider's Avatar
fl_rider
Default Pretty cool but...
That will never fit under a stock hood!!
Chris B
Old Oct 1, 2005 | 10:01 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Nice.
Time to show off the toys? Or taking pix before they get all dirty?
My guess it won't pass smog.
cardo0
Old Oct 1, 2005 | 10:14 PM
big_G's Avatar
big_G
I don't think the blower is big enuf
Old Oct 1, 2005 | 10:26 PM
panchop's Avatar
panchop
showin off, been dumping a ton of cash into this sucker all year and not really anything to show yet but a couple pics.
specs are:
.030 454 2 bolt block machined for 4 bolt splayed maincaps.
4.25 inch SCAT Pro Lightweigt strocker forged crank.
SCAT H beam rods.
Ross flattop 7.5 pistons
Isky Solid Roller Cam 640/650 lift 264/272 dur 112 LC.
Isky Red zone lifters
Isky roller rockers
massaged ProTopline 360cc port heads, 119cc chambers
weiand 871 supercharger
2 Pro Systems 850 holley 4150 carbs
milidon HV/HP oil pump
Milidon 7qt pan.
mallory Unilit dist.
Jacobs wires
hoping to end up near 1000 HP on 10 boost.
Old Oct 1, 2005 | 10:29 PM
Brettmc's Avatar
Brettmc
I HATE when that happens!!
Brett
Old Oct 1, 2005 | 11:26 PM
rosslato's Avatar
rosslato
Wowsa
Old Oct 1, 2005 | 11:49 PM
gkull's Avatar
gkull
Run an off set dist.
Old Oct 2, 2005 | 12:06 AM
panchop's Avatar
panchop
i can fit my mallory unilite in there, unless there is another reason?
Old Oct 2, 2005 | 10:46 AM
gkull's Avatar
gkull
I just didn't think that it didn't have enough room behind the blower.
Does that blower have a burst plate on the front?
I envy blower motors.
Old Oct 2, 2005 | 11:22 AM
Twin_Turbo's Avatar
Twin_Turbo
Whoaa...awesome carporn yeah
Is that your shop? If so..you're not lacking tools... can I come and play there?
Old Oct 2, 2005 | 11:25 AM
ltlevil's Avatar
ltlevil
That motor is ridiculos for a vette. Just think of the stuff you'll tear up. NO way you should put that in your car. NO Sir, instead I'll come pick it up and take it off your hands to save you some trouble
That looks sweet keep us up on how everything is coming along.
Old Oct 2, 2005 | 11:47 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
WOW!!
Old Oct 2, 2005 | 12:35 PM
danboback's Avatar
danboback
Awesome!!!!!!!!!
Old Oct 2, 2005 | 05:28 PM
84rzv500r's Avatar
84rzv500r
Way Way to much..... Is still not enough
To engine for the 75 pro street almost done
Old Oct 2, 2005 | 08:37 PM
norvalwilhelm's Avatar
norvalwilhelm
A Mallory unilite with it's small cap will fit fine. Lots of room.
Old Oct 2, 2005 | 08:38 PM
norvalwilhelm
George there is sufficient room behind the blower to run a small distibutor cap. The pop off for a backfire is located at the back and to the left in this picture. It is there. It is located in the intake manifold.
I found putting the accessory drive behind the blower pulley didn't allow the alternator and power steering pump to fit down low and in front of the heads. I put my accessory pulley in front of the blower belt. This allowed me to leave the spacer off the blower and the belt sits about 2 inches closer to the motor. Less cutting of the hood and easier on the crank with the big blower belt sitting back closer to the front bearing.
Old Oct 2, 2005 | 08:42 PM
norvalwilhelm
Looks alot like mine
