Starter?
Old Oct 3, 2005 | 01:26 PM
doug.storch's Avatar
doug.storch
Default Starter?
Twice in the last week I went for a little cruise. After the cruise there was a breif period of inactivity (about a half hour). When I went to restart I got nothing from the starter. No click, no attempt to crank etc. With the help of a jump and a couple of whacks on the starter with a hammer it started right up. I have a brand new Die-Hard that shows fully charged.
My baby is a '78 L-82 with minor mods (cam, intake and carb)
Does it sound like Sticking Starter Syndrome?
Old Oct 3, 2005 | 01:34 PM
big_G's Avatar
big_G
Yes, it sounds like the starter is about done....
Old Oct 3, 2005 | 01:47 PM
kenko74's Avatar
kenko74
I just solved the exact same problem this weekend with a new battery. When I went to "start," there was no click or nothing. My relatively new battery showed fully charged (I fell victim to the "green float indicator showing green" check), so I assumed the battery was O.K. But a voltage check at the starter showed only 10 volts. Everything else electrical in the car worked. The fact that you didn't get a "click" at your solenoid to me sounds like not enough voltage to engage it.
BTW, while replacing the starter, I also found that my 31 year old battery ground (negative) cable was pretty corroded, and the corrosion had spread deeply into the cable itself. That may have contributed to the battery not recharging fully. The good folks at NAPA built me a new heavy "0" gauge cable with frame ground fitting for $7. New battery+new ground cable=perfect starting.
Old Oct 3, 2005 | 05:52 PM
EddiePear's Avatar
EddiePear
I have found it to be a lot less stressful just to replace the entire starter. I like AC Delco, I have never had a problem with any of there parts. While you are under the car you need to replace the battery cables as well. You should be able to do the entire job for less that $50.00. Not including the battery.
Old Oct 3, 2005 | 10:02 PM
vabeachvette's Avatar
vabeachvette
Did my starter about 2 weeks ago, total of only 2 hrs including the trip to the auto parts store, no problems with getting it out wrt the exhaust, so should be an easy job, the bracket support that bolt to the underbody was the only bolt that was a bit of a pain. If it is shimmed make sure you use the same shims that were in there to begin with. Good luck.
Old Oct 3, 2005 | 11:40 PM
Ironcross's Avatar
Ironcross
Common problem when selling a new starter also. These are exactly the ones that scare me. Amatures playing with a cranking or charging system. Why anyone will take the time crawling around under a car getting all dirty {Vette or whatever} to pull a starter off is beyond me without knowing for sure the starter is the problem. They buy the starter and crawl back under the car, put it on, and guess what? "No Start". They then come marching back and WANT another starter mad as hell!, or some even want their money back. There was nothing wrong with either the old or the new starter. Failure to take precautions and correctly diagnose the problem always ends up this way. If your guessing as most people do, get a pro on the problem and save yourself some money and grief.
PS, if it will start with a jump, more likely than not the starter is ok.
Old Oct 6, 2005 | 01:17 PM
doug.storch
I appreciate the feedback. I did check and the alternator is putting out 14.8 and the disconnected battery checks 12.2.
I think it is starter time, anyone tried CRV starters?
Old Oct 6, 2005 | 05:59 PM
EddiePear's Avatar
EddiePear
Had the same problem last year on my 73, Replace the starter with an AC Delco, replaced both cables and the battery. I have not had any problems after that, I think the starter was under $30.00 and the cables were around $7.00 each. The new battery was the major cost, but your get what you pay for...
Old Oct 6, 2005 | 07:39 PM
anmracing's Avatar
anmracing
St. Jude Donor '09
I agree with starting from the top and working your way down. You may have a bad cell in the battery. This would show plenty of volts until there is draw on the power. It may be something as simple as a ground wire. Check the ground to the battery and also ck the ground to from the chasis to the block. These cars need a ground strap from chasis to block due to the fiberglass. If it does it when its only been driven, then it may very well be the starter or the starter solenoid. A quick way to find out, is the next time it does it, try to hit the starter with some water. If it starts when the starter is cooled down then its time to replace it.
Good luck,
Andrew
Old Oct 6, 2005 | 11:51 PM
glen242's Avatar
glen242
Being a smart a**, you paid under $30 for a starter (rebuilt I assume) and then say "...you get what you pay for...". I guess all us suckers that paid $100 + for a real new starter were screwed.
Let us know how long the $30 starter lasted.
Old Oct 6, 2005 | 11:55 PM
rihwoods's Avatar
rihwoods
solenoid spring....
To Starter?
