Torque specifications?
Old Oct 3, 2005 | 08:19 PM
raider21's Avatar
raider21
Default Torque specifications?
Does anyone know the torque specs for the front end suspension/steering? I found:
Lower steering knuckle - 90 ftlbs
upper steering knuckle - 50 ftlbs
tie rod clamp nut - 132 ft lbs
but still need:
outer tie rod end (ball joint to steering knuckle)
inner tie rod end (ball joint to steering relay)
steering relay to Pitman Arm (ball type joint)
steering relay to Idler Arm (ball type joint)
front wheel bearing nut
any help would be greatly appreciated,
peter
Old Oct 4, 2005 | 12:47 PM
NC C3's Avatar
NC C3
here ya go:
http://www.vbandp.com/instructions/h...specsR0102.htm
Old Oct 6, 2005 | 06:26 PM
raider21's Avatar
raider21
Default tq specs
NC,
Thanks very much.
To Torque specifications?
