Intake Question
Old Oct 5, 2005 | 10:27 PM
Maine Vette's Avatar
Maine Vette
Default Intake Question
I got a phone call today from the guy I bought my Vette from. He said he recently picked up a snowflake intake for a BB that was in real good shape and thought I might be interested in it.
If I'm correct these are aluminum intakes that were cast at winters foundry, but that's about all I know. Anyone mind giving me a crash course?
FWIW, as you can tell I'm green when it comes to engine building which is why I'll be enlisting the help of a mechanic friend of mine when the time comes.
Old Oct 5, 2005 | 10:36 PM
GDaina's Avatar
GDaina
Depends on the casting number, date and if you are interested in an NCRS car. If you don't care about factory correctness, then why bother with the intake...
What intake do you have, and what year car, engine size?
Old Oct 5, 2005 | 10:56 PM
Maine Vette
Having an NCRS car isn't a big concern for me.
From that question I'm assuming these are factory intakes?
Engine is a '73 454.
Old Oct 6, 2005 | 06:41 AM
gerry72's Avatar
gerry72
It is a factory intake, but not the right intake for your car and is not a simple swap since you'd be in the market for a new carb that would fit that intake and, depending on the original application, may not even fit under your hood. Your '73 454 uses an iron lowrise oval-port Quadrajet intake. There were no factory aluminum variants of that intake. Closest was the LS-6 intake, which is a rectangular-port lowriser aluminum with a square-bore carb pattern that mounted a Holley originally.
To Intake Question
