need some help with 69 corvette
Old Oct 8, 2005 | 05:55 AM
adam182003's Avatar
adam182003
Default need some help with 69 corvette
hi every one i have a few qestions im restoring a 1969 corvette that was my fathers car that he bought new in 1969 the frame had rotted out on it (he drove it in the winter) so i purchesed a used frame from down south that was in excelent shape but the tranny mount on the middle crossmeber is diffrent the wholes are the same but it does not have the little ears the frame has ruber mounts on it and i was told they didnt start using rubber body mounts till 72 but was the fram from and auto or a stanard? was there a diffrence in the auto and standard frame? and if it was standard can i use 72 4sp tranny mounts next question any one try the offset trailing arms i wonderinf if you have them how you like them and if ill have any problems or need any modifications when installing
Old Oct 8, 2005 | 07:55 AM
GDaina's Avatar
GDaina
Rubber mounts on 73 and up, but you can use the rubber body mounts. I replaced the aluminum mounts with rubber on my 68.
Auto frame crossmember is removable, 4 speed, the crossmember is welded. 4 Speed car, you can use either one, in fact, changing the clutch with a removable crossmember makes the job a whole bunch easier.
Offset trailing are are used for rims wider than 8". If you are not going to run rims wider rims, offset TA are not necessary.
Old Oct 8, 2005 | 11:01 AM
adam182003's Avatar
adam182003
thanks for the info yah i oder the kit and i have the body mount now for a 69 im a little confusted about your tranny mount answer i get your telling me i have an auto crossmeber then so either i have to modiffy my existing crossmeber or cut it out and put a 4speed crossmember in yah i bought off sets cuase i want to runn wider wheels im running about a 440-500 hp small block in the car its not gona be a trailer queen but its not gona be a car i use very often cuase no matter how safe i drive in it dont mean some one else wont hit me lol thanks alot for you help
Old Oct 8, 2005 | 03:42 PM
Red 69's Avatar
Red 69
You do not have to modify the crossmember, just buy a mounting bracket for a standard trans. You will find a picture and schematic of the bracket and other parts in most part suppliers online catalog. The advantage of the removable auto trans crossmember is convenience removing parts. You don't want to lose that.
To need some help with 69 corvette
