Pulled the Cam/Valvetrain: Results
Old Oct 8, 2005 | 12:50 PM
nastee383's Avatar
nastee383
Default Pulled the Cam/Valvetrain: Results
I pulled the cam/valvetrain this morning. But before I did that I did some rotating of the motor to see how things lined up. I have a slip-fit balacer so that made it much easier to check the positions of everything after each rotation.
With the timing marks at EXACTLY 12 and 12 the balancer showed 8 degress BTDC. With them at 6 and 12 the balancer showed 8 degrees BTDC. The cam is installed 4 degrees advanced and it has 4 degrees ground in. Is that why it shows 8 degrees with the timing marks EXACTLY aligned?
The cam itself looks pristine. I can't visually see anything wrong. It has a good lifter wear pattern in the middle of each lobe, no obvious wear to the gear, no wiped lobes. The rockers are all fine and the pushrods are straight.
However, I do believe my #6 exhaust lifter is collapsed. I've never seen a collapsed lifter before but I think this is obvious. The lifters have the "c clip" type retainers set in a groove . All the lifter plungers except #6 are up against the retainer. #6 plunger is in the down position, about a 1/4" or so from the retainer. Is that a collapsed lifter? They are SPEED PROS. I hope I can buy just one.
Now, would a collapsed lifter keep the motor from firing or would it just make it run ruff?
Old Oct 8, 2005 | 01:09 PM
ltlevil's Avatar
ltlevil
Sounds like the lifter is collapsed, but if you are putting a new cam in you must use new lifters as well. Used lifters (flat tappet) on a new cam will wipe the lobe quicker than a cat can lick it's butt. How did the cam gear look?
Old Oct 8, 2005 | 01:18 PM
Gordonm's Avatar
Gordonm
You could have wiped out the lifter and cam lobe on that cylinder and it should still fire. You also said it was running fine before all this happened.
Old Oct 8, 2005 | 02:48 PM
nastee383's Avatar
nastee383
Its a roller cam/lifters, don't need new lifters for a new cam. Cam gear looked fine.
Old Oct 8, 2005 | 03:14 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
To answer your Q directly, NO there's no way that a collapsed lifter will keep it from firing. It just will not.
Old Oct 8, 2005 | 04:23 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Hmmm.... seems that so far, nothing would indicate a real reason why the engine wouldn't fire...
Very strange..
Old Oct 8, 2005 | 05:50 PM
nastee383's Avatar
nastee383
Very strange..
I haven't found a reason yet. It'll probably be something simple and I'll be embarrassed to admit it but I'm obligated now!
Old Oct 8, 2005 | 05:59 PM
GrandSportC3
I hope that you'll figure it out soon! Keep us updated...
Old Oct 8, 2005 | 06:02 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Distributor shaft ( inside housing ) not busted ?
Old Oct 8, 2005 | 08:00 PM
nastee383's Avatar
nastee383
Appears to be OK. It didn't fire with another dist. installed. Everything I've taken apart and looked at seems OK.
Old Oct 8, 2005 | 08:40 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
why are your timing marks on cam and crank at 12 and 12 instead of 6 and 12?
Old Oct 8, 2005 | 08:44 PM
mandm1200's Avatar
mandm1200
Have a cat, but also have used the same lifters on 3 different cams. No problems. I did that when I was much younger and didn't have money for new lifters.
My money is on the cat!
Old Oct 9, 2005 | 03:05 PM
nastee383's Avatar
nastee383
That's where they are when the motor is at TDC on the COMPRESSION stroke. When a timing set is initially installed at 6 & 12 the motor is at TDC on the EXHAUST stroke.
Old Oct 9, 2005 | 08:08 PM
David Ey's Avatar
David Ey
have you pushed the roll pin out of the dist gear yet to see if it is sheered?
nevermind, I see you tried another dist.
Old Oct 9, 2005 | 09:04 PM
comp's Avatar
comp
Mmmmkay
Old Oct 9, 2005 | 09:17 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
its a long thread....not sure if it was posted..
Have you Ck'd the voltage TO the coil???
Just my 2 cents worth....I am curious now...
best of luck
Mark
Old Oct 9, 2005 | 09:49 PM
bobs77vet's Avatar
bobs77vet
i guess that explains why you have 8* BTDC on both 12 @12 and 6 @ 12.
To Pulled the Cam/Valvetrain: Results
Old Oct 10, 2005 | 12:15 PM
nastee383's Avatar
nastee383
Yes! But why 8 degrees and not 0 degrees? Is it because of the 4 ground in and the 4 advanced on top of that?
Old Oct 10, 2005 | 12:20 PM
nastee383's Avatar
nastee383
Hsvr you Ck'd the voltage TO the coil???
best of luck
Mark
Because the ACCEL 300+ gets its power directly from the battery there is no voltage at the coil with the switch on, very high voltage while cranking. Thats from the ACCEL instructions. However, I checked voltage at the coil with the box disconnected and just the HEI hooked up with the switch on. It was 12 volts.
Old Oct 10, 2005 | 02:20 PM
ltlevil's Avatar
ltlevil
Are we sure the gas is good? Did someone leave a rag in the intake? Hell, I'm out of options at this point, I sure hope you find out and let us know.
