TBI or TPI
Old Oct 10, 2005 | 11:02 AM
smooth-rider's Avatar
smooth-rider
Default TBI or TPI
How much better is TPI than TBI and why.
Old Oct 10, 2005 | 11:05 AM
big_G's Avatar
big_G
The TPI intake manifold design is superior, with more runner length and volume. TPI also allows for 8 injectors instead of 2, allowing better fuel atomization and distribution.
Old Oct 10, 2005 | 11:06 AM
big_G's Avatar
big_G
The TPI intake manifold design is superior, with more runner length and volume. TPI also allows for 8 injectors instead of 2, allowing better fuel atomization and distribution. It was worth 25 HP over the 205 '84.
Old Oct 10, 2005 | 11:09 AM
smooth-rider
Thanks BIG G. Now I know exactly what i'm putting in, no turning back now
Old Oct 10, 2005 | 04:39 PM
Twin_Turbo's Avatar
Twin_Turbo
it was worth 25 HP because the general sabotaged the TBI system, use a similar runner sized TBI system and it'll blow away the stock TPI..honestly. The TPI has long runners, like the CFI and it was also designed for the 305 like the CFI but it certainly does not have this:
without welding this is all you can do:
There's your 25HP..right there.
You're right, fuel distribution is better but it's still batch fire (a whole bank fires at the same time) so it's not much different from the 2 TBs firing in alternate order (or together..depending on enrichment mode) The major advantage is the dry plenum so for the same volume you have more air into the engine because there's no fuel to take up some of the space. IMO the tBI sounds much sweeter, like a carb because of the unequal distribution..it sounds nasty and not like a swewing machine like the batch fire multipoint and sefi systems do.
To TBI or TPI
