Door skin comming off
Old Oct 10, 2005 | 06:06 PM
Re and Cheryl's Avatar
Re and Cheryl
Default Door skin comming off
The passenger door skin is comming off my wifes vette. What should I use to bond it back on and where can I get it?
Thanx
Old Oct 10, 2005 | 06:08 PM
Classic78Vette's Avatar
Classic78Vette
Black silicon putty is whats always used on doors that Ive take apart. Probably get some really cheap at Lowe's.
Old Oct 10, 2005 | 06:16 PM
big_G's Avatar
big_G
Thanx
Evercoat SMC panel adhesive, #993. Can be found at auto paint+body supply houses.
Old Oct 11, 2005 | 12:06 AM
MoneyPit's Avatar
MoneyPit
I agree with Big G. However, if you are in a pinch, and it is just a very small area that needs to be re-bonded, just use some two part epoxy. Take a emory board, or double up some sand paper, and rough up the two surfaces. Then apply the epoxy, or preferrably the Evercoat, and use some pressure. I just did a small area with epoxy on the the 'pit, and used a spring clamp (looks like a jumper cable clamp). It worked like a champ.
Old Oct 11, 2005 | 12:13 PM
nhlgopens's Avatar
nhlgopens
been there - done that...
Old Oct 11, 2005 | 04:38 PM
Re and Cheryl
When I pulled the door I thought it was just the forward corner, but a few tugs later and I had the entire skin in my hands.
Thanx guys
Old Oct 11, 2005 | 04:44 PM
Twin_Turbo's Avatar
Twin_Turbo
then you're lucky, usually those skins don't come off in 1 piece...there ar people out there who wish they did.
To Door skin comming off
