power door lock question
Old Oct 10, 2005 | 09:33 PM
toyvet1's Avatar
toyvet1
Default power door lock question
My 79 passenger door lock is puzzling me. I have replaced the accuator motor. removed everthing and cleand & oiled including the door lock assembly. With the car running the accuator works fine but with the car off the accuator struggles to lock and unlock. The ground on the door panel has been cleaned. Does anyone have any ideas as to how to fix this......drivers side works fine.
Old Oct 10, 2005 | 09:54 PM
big_G's Avatar
big_G
Try swapping switches. Any resistance in the wiring will weaken the action.
Old Oct 10, 2005 | 10:31 PM
77 Vette Girl's Avatar
77 Vette Girl
Try digital volt meter and ohm meter on every connection, running and off. Compare readings to working lock, this should tell the problem but not how to repair it. Good Luck.
Old Oct 11, 2005 | 06:30 AM
Gary79's Avatar
Gary79
the problem might also be if the door is sagging because of worn hinge pins and bushings. try wiggling your drivers door up and down by putting your hand under the door and lifting. I did this plus clean and lube everything and i have funtioning door lock, whereas i did not for years.
Old Oct 11, 2005 | 08:52 AM
Crash80's Avatar
Crash80
My 80 was just like that when I bought it. I bought new actuators and that worked for about a year or so. It is intermittently doing it again. I have just learned to live with this annoying litte Vette quirk for now.
To power door lock question
