I found the electric choke in the glove compartment ,Just bought a 81 with a edelbrock carb.. When i installed the choke and connected the wires the choke closed when the power is on .. (Working backwards) any ideas, I thinking of reversing the choke spring
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
a lot of the electric chokes use springs that are heat sensitive and when the spring is cold from not having any power to it it closes, when you turn the power on the spring starts to heat up (irrespective of the engine running) and slowly starts to open...sounds like this one is just misadjusted.
