Help me pick components for my "perfect" 427
Want to help?
This is "bang for the buck" engine, not an all-out racer. I've got goals I'd like to meet, but not at "any" cost.
I would be dropping it into my 68 Vert. Cruise RPM is about 1800 RPM with the TKO-600. I NEED it to lug along happily at that RPM, cause I do alot of highway cruising. Not interested in forced induction, EFI, or nitrous. I'm good with a clutch, so I'm not much concerned about torque, but would like it to redline around 7,000. That leaves me with a desired power band for the cam between about 2000 and 6500, right? I'd like around 10:1 or 11:1 compression, so it'll run happily on 94 octane.
According to DynoSIM 2001, I should hope for 700 hp...realistic?
I'm not too hip on the raised exhaust ports of most of the performance heads. I'm running sidepipes and that extra .6"-.7" is a lot...
What I already got, so far...
Gen IV Bowtie block, in crate
GM Forged 427 crank
Holley 850 DP
MSD Digital 6 Plus
MSD Pro-Billet dist.
Crane stainless roller rockers, 1.7 ratio
Need yet to select:
Heads (thinking GMPP 400's or 410's)
Cam/Lifters/pushrods
Oilpan & pump/pickup
Conn. rods (I've got a set of GM std. forged, but would consider upgrading)
Pistons
Gaskets
Flywheel...(I've got a L88 10.5" nodular and a 11" cast...which to use?)
Damper (again, I've got a GM damper already, but...)
Questions I've got so far...
For heads, is it best buy bare castings and separate springs, valves, etc. and have everything worked (3-angle, porting, etc.) or better to buy an assembled head and disassemble, do the cutting work, and reassemble (or just not bother with the metal work at all)? I've heard that valve seal is marginal with over-the-counter assembled heads...true?
Cam/lifters...variable duration lifters (Crane, Rhoades, etc)? Roller or flat tappet? Follow DynoSIM recommendations for lobe specs or let the cam grinder make the call?
Oilpan...for a cruiser/occasional auto-x'er, is it really worth it for a $$$ pan from Hamburgers or Milodon? Scrapers/windage trays worth it?
TCI Rattler or Fluidamper worth the extra $$$?
Thanks for helping me spend some money!
Rpm Air-gap intake
Brodix Race-rites heads, a 400 cc head is WAyyyyyyyy too big. I did not know GM even made them in a non race head.
Cam: solid roller (or flat tappet) in the area of 245-250 at .050 on a 110, .650 lift
If you are going to run 94 octane I would run 11.5 to 1 compression.
Pro-systems or other 1000 cfm Annular discharge carb. Your 850 is fine also.
A lot of guys are having good luck with Eagle rods, good deal for the price. There are better, but for a sort stroke 7000 rpm motor the Eagles will be fine.
The Rattler is far better than the Fluidamper
Here's the write-up for the 410:
Technical Notes: These heads are made from 356-T6 aluminum alloy. The 9/16" deck surface is for maximum strength and great head gasket sealing. Designed for 3/8" push rod diameter. These heads require cylinder head bolt kit P/N12367779. Use the following performance head gasket 1965-1990 with standard bore to 4.370" use P/N 12363414 and with 4.47" to 4.540" use P/N 12363413, and with Gen 1991-1996 engines with standard to 4.370" use P/N 12363412, with bores of 4.47" to 4.54" use gasket P/N 12363411. The semi-finished bronze guide can be finished either 11/32" or 3/ 8" . The interlocking hardened valve seat will accept leaded or unleaded gas. Use intake gasket P/N 12511789.
GM Performance Parts 401
This is the smallest rectangular-port GM Performance head, yet it flows extremely well for its size. Having a very similar port volume to the 990 head the 401 head flows dramatically better, especially at higher lifts. With the combination of great flow and being lightweight, this head would make a great mid-priced aluminum head for a hot street rat motor.
Other than that...why only go 427ci?? That may limit your streetablitly to achieve 700hp and cruise at 1800rpms.
If a 454 crank works in a 427 block the 4.25 stroker crank would also fit and you get 496 cubic inches and 600 plus horse is no problem with a mild 288 street roller cam a oval heads.
A 427 at close to 700 horse would not run happily along at 1800 rpm on the street.
Go with cubic inches.
I don't have a specific HP goal. My only firm goal is a useable power band between 2000 and 6500...
I'm completely open to bumping up the bore, but I'm not sure I want to buy a new crank...
Why not a crank??? The cost of everything else is the same. A 496 is going to put alot more grunt then say your 435 once bored.
Even based on a mild 1 horse per cubic inches the 496 is ahead 60 horse and way more in torque.. Pistons, rods, cam all cost the same regardless of cubic inches. I would not even bother anymore with a 460.
When looking at flow charts flow in the .800 range is useless. In a street cam I wouldn't go with high lift. I would stick around .625 or so for long roller lifter life.
Also a rough idea of what a head can support in horsepower assuming no intake and flow readings are everything.
.254 x flow in cfm x 8 cyliners = horsepower.
A good intake and carb take away 15 or 20% of this so you are down right away.
Take the head from above at .600 lift. It's maximum horse it can support is .254 x 308 x 8 = 625
Take away 20 % for intake and we get .254 x 248 x8 = 503 realistically.
That is roughly what that head should support if everything else is working well.
Regarding the crank...if you can swing it, pop in the 4.25 incher, you will have no problems reving to 6500 or even 7000 either the 288 or 308 cams.
Heads...sheeesh...there are so many choices...Brodix, GM, Edelbrock....blah...blah...blah....if you are not going to race, then look for smaller intake runners, stop light to stop light you will have tons of torque...
Pistons....anything in the forged 10-11 C.R. will be fine...I'm running 10.5 and 93 octane is just fine.
Carburation and intake....too many choices and I wouldn't know where to begin.
Mostly because I've already got a nice forged 427 crank. I could sell it to get a longer one, but I won't get out of it what it's worth...
So, what's the recipe for a 496 or 509? I kinda dig the idea of a 509, cause that was the last big engine my dad built (about '89)
Or you could go out to a 4.600 bore and get 500". Still a screamer.
But I would go along with Norval's idea and get a crank. Eagles and SCAT's don't cost too much and are an easy way to at least 540" in your block. That's a proven combo that will rev and live well even with a 4.25 crank. Mine has been together for years now as well as several other buddies. The newest version makes 825HP on dyno and turns over 7000 rpm on 93 octane. The mildest version made 732HP and was a TQ monster.
If you go with stroker, you need longer rods...6.385's at least. They are common.
I'd look at other heads. The GM/Edelbrocks are OK, but the Brodix and AFR's are much better IMHO. The raised ex port isn't that big of a deal..there are Forum members here with the AFR .300 raised ports and no issues. I have the .600 raised Brodix and it seemed to actually help the fit of the Hooker 2-1/8" headers on mine. The Race Rite Bordix have the ports in stock location though.
Get a good oil pan. Get at least the GM LS-7 pan, it does well, but I can tell you the drag race Milodon I have now on mine does much better. Oil pressure stays much better than other pans I've tried. But the LS-7 will do good too for less extreme applications.
The whole cam and head choice comes from what cubes you decide. There are lots of combos here to help pick from.....
But I can tell you a solid flat tappet or roller is better than a hyd anything.
Narrow down the choices some and we'll ehlp all we can!
Jim
Check out www.cncmotorsports.com, you'll be surprised at how reasonable a lot of this stuff is nowadays. Most of the new "cast" Scat parts are stronger than the old GM steel cranks. Good luck
I also dig the idea of the 540. Let's go with that. I might even have a forged 4.25 crank laying around...I'll have to check.
