alternator upgrade..have ?
Old Oct 12, 2005 | 05:00 PM
onaqwst's Avatar
onaqwst
Default alternator upgrade..have ?
i have a 85? amp alternator and want to upgrade to a 140amp to help power up my audio system...... do i have to upgrade any other wiring to the fuse panel or anything else?.......
b
Old Oct 12, 2005 | 05:11 PM
Re and Cheryl's Avatar
Re and Cheryl
Your gonna need an 8 gauge or maybe bigger wire running to the alternator. Everything else should be fine as your system amps will draw power directly from the battery
Old Oct 12, 2005 | 07:05 PM
bs82vette's Avatar
bs82vette
See http://www.madelectrical.com
Old Oct 13, 2005 | 04:43 AM
stickboy's Avatar
stickboy
run a 8 gauge or larger wire from the battery post on the alternator to the battery post on the starter. Keep the stock wire connected that runs from the alternator to the battery. This is the easiest way.
Old Oct 13, 2005 | 08:54 AM
norvalwilhelm's Avatar
norvalwilhelm
Do not go with the one wire alternators. I did and regret it. I have a 150 amp truck alternator and a number 6 wire going directly to the positive lead on the starter solenoid.
A one wire reads the voltage off the alternator and if you have a heavy draw under the dash this type of sensor doesn't repond properly.
If you go with a remote sensor it boosts the alternator output to maintain about 14 volts under the dash by upping the alternator output even as high as 16 volts. If you run a remote sensor and a direct line to the battery it overcharges the battery because now the dash sees 14 volts, the alternator sees 16 volts and you battery sees alternator voltage and overcharges.
I would stick with the 3 wire and larger alternator.
Old Oct 13, 2005 | 11:30 AM
68/70Vette's Avatar
68/70Vette
Originally Posted by bs82vette
Their phone number is 559-539-7128. I've called many times over the last week and no one answers. Not even a voice mail.
A year ago, Mark was having some health problems. Wonder if he's OK. Anyone know????
Old Oct 13, 2005 | 01:35 PM
onaqwst's Avatar
onaqwst
so, what's the difference in the number of wires for alternators...i.e. 1 wire/4 wire etc....... i was gonna run 4 gauge from the alternator to the battery..... since i have new digital gauges that i tapped into a wire 12volt at the battery then would i have any issues with over charging (does that sound right?)... so i guess if i go with a 3 wire then what wires go to what.....cause i have a 4 wire right now....... 1 ground/1hott/1 sensor?....not really sure..... educate me right quick.....
thanks
b
Old Oct 13, 2005 | 01:52 PM
norvalwilhelm
thanks
b
Read this
http://www.madelectrical.com/electri...hreewire.shtml
Old Oct 13, 2005 | 02:59 PM
onaqwst's Avatar
onaqwst
thanks.... i guess i was just being a bit lazy...
b
To alternator upgrade..have ?
