Help! Is this estimate reasonable???
When I bought my '79 L82, there was a noise in the rear. I thought it was a bad tire. Took it to a local shop to have it checked out and guy said the differential was shot. Gave me a quote of $2100 for rebuilt differential and installation. I suspected this was going to be an expensive hobby, but I'm still in shock! Does this sound reasonable? Checked out online suppliers for rebuilt units and they seem to range from 800-1100 bucks. $1000 labor? I'm going to another shop for another estimate but I need some advice fast!
Thanks,
Jim
Thanks,
Jim
Thanks again,
Jim
Thanks again,
Jim
Appreciate you taking the time to respond.
Jim
Jim
However, any time we need to buy parts for it, everyone assumes that the screws/bolts/nuts is metric, or that because we say the name "Jaguar" the parts/labor needs to be 3 times as much as for a regular American car.
Sure, it's got its own quirks, but when you've got an engine that was basically the same block/engine from 1949-1987, there's lots of standard parts for it!
As for your issue with rear diff, that sounds a little pricey. I mean, Year One's got performance differentials ranging from about $425-$600, and overhaul kits for $114-$140, depending on the differential.
Now, granted, I'm not exactly certain all of what's being done to the rear end, but let's assume that he's getting a brand new differential, and he pays in the neighborhood of $600 for the parts. Is the rest of it going to cost $1500 for labor?
Yeah. DEFINITELY get a second quote on that! Sounds like he might be trying to soak you because your car has "Corvette" on it.
Thanks for taking the time to respond.
Jim
When I bought my '79 L82, there was a noise in the rear. I thought it was a bad tire. Took it to a local shop to have it checked out and guy said the differential was shot. ...
I don't know how experienced you or your shop is with the Corvette IRS, but this noise could be related to any of a myriad of issues. Everything from a bad U-joint to a wheel bearing to even a differential. I would recommend that you first confirm that your differential is shot before you conclude this is gonna be expensive.
I recommend that you get a Corvette specialty shop or someone experienced with this rear to take a look at it to at least confirm the diagnosis. The cost of these repairs go from relatively inexpensive to quite expensive. If you've already done this or are comfortable with the capability of you shop… forget everything I said…
Good luck… GUSTO
I recommend that you get a Corvette speciality shop or someone experienced with this rear to take a look at it to at least confirm the diagnosis. The cost of these repairs go from relatively inexpensive to quite expensive. If you've already done this or are comfortable with the capability of you shop… forget everything I said…
Good luck… GUSTO
My wife didn't really want to go to Cancun this winter, did she?
Thanks for the input.
Jim
However, just replacing the differential with a new one, and putting new half shaft u-joints on while you're at it, is not that bad a deal - little adjsutment type things, more R&R than anything else. Just make sure the puppy is secure when you get under there!
BTW, getting newly rebuilt entire BB half-shafts from someone like VanSteel or wherever you're looking at diffs is not that expensive and easier than fighting with popping out those ujoints without bending the yokes.
Last edited by WayneLBurnham; Oct 13, 2005 at 11:36 AM. Reason: just thought of something else
That's correct, you'll have time enough during the winter and here you can get all the neccessary info during your project...
I had noise "back there" and the differential was not causing it - there is so much that can make noise: U joints, wheel bearings, worn bushings .... in my case it was loose and rotted parking brake hardware
This is definately a job you can do yourself, disassemble and post your findings (photos) here.
Jim
One of those ATV/snowmobile jacks works wonderfully at helping to lower IRS/diffs. The Jaguar guys do this all the time when brakes need to be changed, because the pads/calipers are located right next to the rear diff.
Cheap tool if you have to get in/out of the diff area a lot; Pep Boys sells them for about $100; same with Costco (when they have them in stock).
These are also handy in lowering the transmission out of the car, if you're leaving the engine in the engine bay, since they're generally a big, flat surface area to help spread the load...
