Birdcage Rust?
Old Oct 13, 2005 | 02:48 PM
Wuttin's Avatar
Wuttin
Default Birdcage Rust?
Folks,
After following the thread about the poor guy from Canada with the rusted out frame I got to thinking. I recently took off my rocker panels when replacing my side pipes. The metal to which the panel is attached is pretty rusted out on the passengers side (the drivers is ok). I knocked off all the loose stuff and sealed what is reachable, but you can only get so high. Do the rocker panels connect directly to the birdcage? The frame itself is solid with no issues I can see/hear/feel. It is a 1979 raised in Florida until 2003. Are there other spots on the birdcage I should check that are easy to get to for a visual? I changed out the weatherstripping on the windshield and found only minor spots under the trim which I dealt with. Thoughts?
Many thanks,
Steve
Old Oct 13, 2005 | 03:06 PM
adam182003's Avatar
adam182003
ill try get you some pics of my old frame that rotted out the front of the frame was all right only the back half rotted out it was ny car all its life
Old Oct 13, 2005 | 03:52 PM
stingraymaniac's Avatar
stingraymaniac
Take a look at Kortensi´s thread:http://forums.corvetteforum.com/show...0&forum_id=119
There you have plenty of pics of the birdcage and where it rusts
Old Oct 13, 2005 | 03:53 PM
stingraymaniac
Was it Kortensi you meant?
ore else take a look at his thread:
Meny nice pics and stuff there
Old Oct 13, 2005 | 04:03 PM
Wuttin's Avatar
Wuttin
Check out the thread posted by surkon on the 7th of October.
These are great pix..thanks
To Birdcage Rust?
