confused about cam choice
here is what i have...76 l-48 350, stock bottom end (82,000 miles but good compression), 3.08 rear gear, stock auto trans (with B&M shift kit), stock converter, stock tire size, hooker headers with side pipes & baffles, hei dist with lars recurve kit, 650 speed demon with elec choke & vac secondaries, edelbrock rpm intake, 70 cc edelbrock rpm heads, comp roller tip rockers (going to get the pro magnum full rollers when i order the cam, not sure on 1.52 or 1.62 ratio either).
i know that in addition to the components that you have, satisfaction in a cam choice is based on what you want and how you drive. i dont race it, and its not an everyday driver (i do drive it to work sometimes when the weather is nice). its mainly just a weekend cruiser that i want to be fun to drive (ie. occasional tire chirp or burnout
). im interested in torque, 2 lane passing power, and in general throttle response that you can feel in the seat of your pants. an upgrade to 3.55 gears would probably help, and that may be my project for the winter after next followed by suspension upgrades (next winter will be alum radiator with dual spals), but now is the time to decide on a cam.i like what i've read about the lunati voodoo cams (.437"/.454" lift, 250/256 dur), comp cams he 268h (dont think i will gamble on the xe series), the edelbrock performer plus cams (.420"/.442" lift, 278/288 dur), and the crane powermax (.432"/.459" lift, 256/268 dur). which of these (or what other) would be a good choice for what i want? any advice and all responses will really be appreciated. thanks in advance.
just a thought if your are scared away from the XE series why are you attracted to the voodoo cams? Cams are like girl friends you will get a million different responses....i have the XE 268 and i like it....maybe the 268h would be good choice for you they are different then the XE series, the other two cams (from crane and edelbrock) seem ok also. just not sure why you would want the voodoo if the XE scares you
auto trans. and 3.08 gears. My L-79 (68) with that cam doesn't start pulling till 3,000 rpm.
Best advice I ever heard on cam choice:
Do all your homework, find the best cam for your car/driving habits.
Then get 1 size smaller cam! JMHO
Rick
Rick
You beat me to it, great street cam (262), good manners, etc-will make plenty of usable torque. Edelbrock RPM cam way too big for an auto, stock converter and gears. Nothing wrong with a hydraulic roller, over 124,000 miles, no problems at all
I guess I would look for a cam that really maximized the torque.
trw
Looks like a good modification to me.
BigBlockk
Later.....
http://www.jegs.com/webapp/wcs/store...0707&langId=-1
Number 270-100042 is the one I would get.
BigBlockk
Later.....
