any tips??
Old Oct 14, 2005 | 11:23 PM
gator79's Avatar
gator79
Default any tips??
I am pulling the trans to replace the torque convertor, I have had the engine out a few times and the trans once, but the engine was removed at the time. are there any tips or tricks, looks like the driveshaft might be fun. it is a 1981 with a th350c trans.
Old Oct 15, 2005 | 12:14 AM
BigBlockk's Avatar
BigBlockk
When I pulled the transmission out of my '70 years ago I made a support for the back of the engine that looked like this.
Code:
I       I
I  oil  I
I  sump I
I       I
I-------I <---A
I       I
I       I
I-------I <---B
Material was 2x4's. The oil pan sump fit down between the up rights. Cross beam "A" was just a little bit shorter than cross beam "B". Oil pan mounting bolts (NOT THE OIL PAN ITSELF) rested on the top of the 2x4's. I used nails at "B" and screws at "A". When I had everything set in place I tightened the screws at "A" to clamp the support in place. Of course you need to remove the starter and oil filter before you put this in place.
BigBlockk
Later.....
Old Oct 15, 2005 | 08:10 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you should have no problem with the drive shaft....it looks worse then it is
To any tips??
