headlights on a 1976 stuck open
Old Oct 15, 2005 | 08:59 PM
fmaella's Avatar
fmaella
6th Gear
Default headlights on a 1976 stuck open
Can someone recommend a good manual to troubleshoot vacuum problems. I headlights are stuck in the open position. If anyone has some troubleshooting tips, I will take that also. thanks in advance.
Old Oct 15, 2005 | 09:02 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
http://www.corvette-101.com/
Follow the link on the left side to vaccum troubleshooting.
Old Oct 15, 2005 | 09:11 PM
fmaella's Avatar
fmaella
6th Gear
great web site. thanks
Old Oct 15, 2005 | 11:34 PM
motovate's Avatar
motovate
Default Head lights stuck Open
I'm not sure if the 76 is the same as a 74 but I had the same problem with my 74 and it is a vacume issue. There is a vacume release switch just under the dash that slides open or closed to release the vacume and allow the lights to close. There is a **** that sticks down - unless it is broken off like mine was - have to kind of bend around to see it. Might try loooking for it. I just had to open/close it once for mine to clo se and start working again.
LBM
To headlights on a 1976 stuck open
