Shift kits
Old Oct 16, 2005 | 04:46 PM
casedog22's Avatar
casedog22
3rd Gear
Default Shift kits
Hey all I have a 77 vette with a L-48 engine in it. I was wondering about putting a Hurst dual shifter in it or a transgo shift kit. Does anyone have one or know how well they work. Im wondering if Im just better off switching to standard all together. Thanks casey
Old Oct 16, 2005 | 05:47 PM
comp's Avatar
comp
used before
Old Oct 16, 2005 | 06:18 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Well I'd take a standard trans any day but shift feel and timing are much improved with the "Shift Improver Kit" I installed. It's only a hard shift when you're really on the throttle, normally it's just a nice quick shift. Win-win situation
-Chris
edit: oh and cleanliness is a must. Don't try to use latex gloves as they'll just melt and fall apart into the transmission. The directions kindof suck but I was able to figure out what they meant, or you can ask here.
Old Oct 16, 2005 | 06:28 PM
casedog22's Avatar
casedog22
3rd Gear
-Chris
I will take this advice because I will need all I can get. But what did you install the hurst ot the Trans-go. Also having this in your car pretty much turns it into a 3-speed manual with-out a clutch right?
Old Oct 17, 2005 | 03:06 AM
hensen1954's Avatar
hensen1954
Trans Go for me.
First used one in my 1971 429 SCJ Mustang - perfect results - perfect instructions.
So, now I got a kit ready for my 81 Vette.
Well, actually I got two !!
Paid for one but they sent two kits.......... spare one on the shelf I suppose.
Old Oct 17, 2005 | 04:27 AM
Yeller81USNRet's Avatar
Yeller81USNRet
Put a B&M in my 81 and love it ..Went with the Street Strip setting.
Done this about 2 years ago and no problems.....
Old Oct 17, 2005 | 05:11 AM
LiveandLetDrive
Oh sorry we are talking about two different things. If you want to shift manually you need to get a full-manual valve body. What I was talking about was the shift kits that are just a plate that goes between the valvebody and the transmission case. Same auto shifting just better. And I used the B&M Shift Improver Kit in "street/strip" form.
-Chris
To Shift kits
