The big red one is the alternator's positive voltage output.
The big black one is the ground wire.
The two in the plastic connector are the field current and the sensing voltage wires (can't recall which is which without my wiring diagram).
The sensing voltage wire detects voltage changes in the car's electrical system. When changes occur, the other wire supplies or removes current to or from the alternator to increase the magnetic field which produces more or less voltage output to the system.
You have a 3 wire alternator. The big ground wire is not really needed, but provides a better ground. If you look closley it attaches to the case of the alternator. The case is already grounded through the mounts. Since you already have the wire for a 3 wire get a 3 wire, the sensing wire allows them to work better when the engine is at or near idle.
Yeah...I figured that, but wanted to be sure before ordering.
Interesting article. If you have all factory wiring maybe dont go that route, My one wire works fine with a massive electrical demand with no issues.I do have all new wiring for the purpose of what I use it for.The alt is set up for 100 amps charging at 2000rpm and less as rpm goes up .
Cali has a 68, and all 68 alternators have external regulators...that's the little black box that Cali was describing, right next to the horn relay.
Starting with the 69 model year, the regulators were built in the alternator
