antifreeze capacity
Old Oct 18, 2005 | 10:56 AM
70Donnybrooke's Avatar
70Donnybrooke
Default antifreeze capacity
I had to replace my heater core and was wondering how much antifreeze I need to buy. I was thinking 2 gallons. I just wanted to be sure. It is a small block 350 auto, so it has the copper rad.
Old Oct 18, 2005 | 12:00 PM
marshrat99's Avatar
marshrat99
Buy two gallons non-diluted antifreeze. Mix 50/50 with water. That should be plenty.
Old Oct 18, 2005 | 12:20 PM
70Donnybrooke
Thanks for the help.
Old Oct 18, 2005 | 12:38 PM
PRNDL's Avatar
PRNDL
Check your owner's manual. In the back it lists capacities. In 68, the cooling system with heater is 15 qts for a smallblock and 21 qts for a bigblock. Probably the same in 70, so 15 qts is one qt shy of 4 gallons, so that's where you get the 2 gallons mixed with 2 gallons of water. One problem: You will have to fully drain your system including the engine block to make room for the full amount of diluted antifreeze. If you drain and flush your system at the radiator then there will be a lot of water left in the system and you will be lucky if you can fit 2 gallons of undiluted antifreeze in.
To antifreeze capacity
