Which 4 speed trans for a big block??
Old Oct 20, 2005 | 05:25 PM
viperjesse's Avatar
viperjesse
Default Which 4 speed trans for a big block??
I plan on installing a 454/500 hp while converting to a 4 speed trans.
Will an M20 be strong enough? A 6 speed isn't in the budget so I'd like to stick with a Muncie or T10.
Can someone tell me the differences between the 2?
I was tols the M20's won't hold up to the horsepower of a big block.
I will not be running sticky tires or going to the track.
Thanks in advance.
JZ
Old Oct 20, 2005 | 05:46 PM
Corey_68's Avatar
Corey_68
Thanks in advance.
JZ
It's not a question on IF but WHEN the 4spd will go out. I have yet to take my Vette to the strip and don't power shift and the 4spd is already having to be rebuilt. Go w/ a T10 in the least. Next June I'm swapping in a Viper T56 6 speed.
If you baby your car, never take it to the strip (especially w/ slicks) and on'y for parades then you'll be fine. But if you drive the way it was intended buget $$$ for a rebuild
Old Oct 20, 2005 | 05:55 PM
big_G's Avatar
big_G
Look for a M-22 (expensive) or a Super T-10. I believe they are stronger than M-20, 21 or regular T-10. If you can spend a little more, I think a Richmond 5-speed is stronger than a M-21
Old Oct 20, 2005 | 06:13 PM
Todbo's Avatar
Todbo
good question viperjesse , I'm listening
Old Oct 20, 2005 | 06:16 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I blew 2 Super T10's with my 406ci in short order so I would not recommend putting one of those behind anything with some serious torque
Old Oct 20, 2005 | 06:35 PM
rihwoods's Avatar
rihwoods
I have a Borg Warner Super T-10 in the 78 Smallblock. Have raced it in autocross,and have power shifted...still going strong...
Have an M-22 behind the 69 502....no problems,but have not drag raced it....just road stuff so far...check Richmond out for a 4 speed...or get a M-22
Old Oct 20, 2005 | 08:36 PM
MotorHead's Avatar
MotorHead
Wish I had a thought of that "Accerlatus Maximus" that's a good one
Old Oct 20, 2005 | 08:49 PM
viperjesse's Avatar
viperjesse
Thanks guys.
Any more? Keep em coming.
Looks like I'll have to change my budget for the trans.
Old Oct 20, 2005 | 09:16 PM
ZL1powr's Avatar
ZL1powr
I drag raced several years with an M-22 behind BB engine combo's ranging from 500 HP to greater than 600 HP. That trans is still going strong in my blown BB 65. A Richmond six speed did not hold up. Jurry is still out on the TKO-600 that replaced the Richmond.
Old Oct 21, 2005 | 10:36 AM
Nate '69's Avatar
Nate '69
I'll second that a stock richmond 6 speed will not hold up... I sent mine back to have additional upgrades and it's still holding strong but not drag raced, only spirited street driving
Old Oct 21, 2005 | 03:10 PM
Lasse's Avatar
Lasse
No problems as long as you won't run really sticky tires. I've run mine for five year without problems with a 468 cui 520 HP and 295/50-15 tires.
Old Oct 21, 2005 | 10:41 PM
my72vette454's Avatar
my72vette454
I blew my old stock saginaw 4 speed the other day. I have been careful not to bang gears in it so I didnt tear up the trans or the rest of the drive train behind my twin turbo 468 but the other day I was taking a friend for a ride and was accelerating in third gear and somthing went bang and that was the end of it so i am looking for somthing stronger too. Are there any 5 or 6 speed transmissions that will take 800 hp/ft lbs of torque?
Mike
Old Oct 21, 2005 | 11:06 PM
GDaina's Avatar
GDaina
I'm running a Doug Nash 5 speed (same as Richmond 5 speed)...as long as you don't go nuts with the power shifting, you will be fine with any stick...it's the power shifts that tear up the rear ends and trannys
Old Oct 22, 2005 | 07:13 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I went with an M-22, only because I wanted a direct swap-in and it was a very limited option that year. No racing, and only about 1,000 since rebuild.
Old Oct 23, 2005 | 10:57 AM
viperjesse's Avatar
viperjesse
When you talk about power shifts do you mean banging gears?
Old Oct 23, 2005 | 11:26 AM
GDaina's Avatar
GDaina
Yes..you can throw a quick shift and it's easy on the hardware, the gear banging is what tears things up
Old Oct 23, 2005 | 01:06 PM
30cal's Avatar
30cal
Thanks in advance.
JZ
The problem with the M21 and M22 in a street car, with stock rear gear ratio, is they both have a 2.20 first gear ratio. The M20 has a 2.52 first gear ratio, much better off the line. You could go with a 4.56 or taller rear gear to compensate (with the M21 or M22), if you don't mind running down the highway 70 mph at 3500 rpm.
If you aren't going to the track, just want to romp on it every now and then, go with the M20. You'll be much happier with the way your car leaves in first gear....
Old Oct 23, 2005 | 09:18 PM
Marks69BB's Avatar
Marks69BB
Default Go for the Kiesler Tremec TKO-600!
If I were you, I'd go with the TKO-600 for piece of mind. It is a short-throw rail-shifted tranny, locates their look-alike shifter in the stock position, and IMO it is bulletproof. With it's 3.27 first gear you can run a 3.08 - 3.73 for incredible off-the-line performance and have an OD 5th gear for low RPM cruising - the best of both worlds!
At ~$3800 the kit ain't cheap but on these cars, what is?
I exploded the non-original M20's tailshaft housing with my BB's torque just doing burnouts with TA radial street tires.
To Which 4 speed trans for a big block??
