Engine Vibration
Old Oct 21, 2005 | 06:21 AM
inex1's Avatar
inex1
Default Engine Vibration
[FONT=Arial Narrow]
I recently purchased two C3 Vetts, one 1980 wigh a poor body but a engine with 56 K on it and a very stright 79 with a blown stroker engine. I removed the blown 79 and install the good 80 engine which was an automatic. Used the flywheel and harmonic balancer from the 79 because it is a stick. I notice a vibration starting at 1200 and gets worst as the rpms increase, could the stroker flywheel and balancer be my problem ? I did a compression check and all cylinders arre in the 178 - 182 range, all plugs are super clean and seem to be firing well. I really am confused. Any feedback will be much appreceiated. Also have a 80 car to part out and will be very rreasonable price wise. http://forums.corvetteforum.com/newt...newthread&f=3#
Frown
Old Oct 21, 2005 | 06:46 AM
Rickracer's Avatar
Rickracer
8th Gear
Default Flywheel and balancer are your problems
They are most likely 400SB parts, and are externally balanced. You need a (neutral or zero balanced) 350 flywheel and balancer.
Old Oct 21, 2005 | 06:49 AM
GDaina's Avatar
GDaina
Can't use 400 flywheels and harmonic balancer
Old Oct 21, 2005 | 10:16 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
does it have a fan clutch onit? remember to check this out also
To Engine Vibration
