Strange "squeeling" sound
Old Oct 23, 2005 | 09:17 AM
theandies's Avatar
theandies
Default Strange "squeeling" sound
I put my hardtop on yesterday and went for a drive. I noticed a squeeling sound coming from somewhere. I could not pinpoint it but it's not coming from the back of the car. It sound like its coming from the dash area. It only made the sound while I was moving. Anyone had any sounds like this coming from the dash area? I am going to get my cousing to ride with me today and try to pinpoint it. My tranny is on its last legs but I don't think it could be that it because the noise stops when the car stops and there is no sound when the tranny is out of gear and the clutch is not pressed. Could I be hearing a vacuum leak?
Old Oct 23, 2005 | 09:22 AM
MidShark's Avatar
MidShark
Possibly your speedo cable? Doesn't usually make what I'd describe as a squealing noise when going bad, but you never know.
Rich
Old Oct 23, 2005 | 09:43 AM
theandies's Avatar
theandies
Rich
I was thinking about that and the tach cable but I ruled out the tach because it stops when the car stops. I'll change my speedo cable (or lube it) when I pull the tranny soon.
Thanks Rich
Old Oct 23, 2005 | 06:53 PM
jimbow's Avatar
jimbow
fan belt? loose? upside down?
Does it squel at the higher RPM just before changing gears?
Does it come & go w/ acceleration?
You can check this in the hood by "goosing " the carb and see what happens...mine was hitting the bottom of that whatchamacallit hooked onto the alternator adjusting bracket. good luck , jim
Old Oct 23, 2005 | 08:00 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I usually get a squeal coming from the passenger seat when there's a woman in the car...Mysterious....
Old Oct 23, 2005 | 09:13 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
sure its not the front brake pads moving around?
Old Oct 23, 2005 | 09:32 PM
Hwy St*r's Avatar
Hwy St*r
Coming from the back of the car? U-Joints?
Old Oct 23, 2005 | 10:36 PM
hdman1962's Avatar
hdman1962
Old Oct 24, 2005 | 02:31 PM
redc3's Avatar
redc3
you look just like a hog.
Old Oct 24, 2005 | 02:34 PM
Hvymtlc5's Avatar
Hvymtlc5
slipping / glazed belt?
Old Oct 24, 2005 | 06:52 PM
Chopper Larry's Avatar
Chopper Larry
With the windows down you should be better able to determine whre it's comin from;
I just found out about a worn out U-joint on the inside of the passenger side inner half-shaft; was thinkin it was the rear end.
Old Oct 26, 2005 | 05:52 AM
theandies's Avatar
theandies
Thanks for the sugestions guys
I know its not the belts or the u-joints. All my u-joints are brand new. The only thing I've done since the noise started was to install the foam seal between the bell housing and the trans tunnel. I am removing the trans this winter for rebuild (on its last legs) so the noise may be coming from it or something related.
Old Oct 26, 2005 | 09:45 AM
red topless gator's Avatar
red topless gator
My speedo cable made a squeeling noise. tried to lubricate but no dice. replaced cable and everything is grea t....LT
To Strange "squeeling" sound
