Frame replacement
Old Oct 25, 2005 | 07:12 PM
albertsizemroe's Avatar
albertsizemroe
Default Frame replacement
I have a 72 Vette with a bad frame, I found a 78 rolling frame for sale .Is the frame the same except for the front and rear bumper mounts?Will it work????
Old Oct 25, 2005 | 07:16 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Im pretty sure it will work. the 78 and 79 frame were the thickest of all the years so it whould be good for a racer.
Old Oct 25, 2005 | 08:33 PM
enkeivette's Avatar
enkeivette
Thats good to know, I have a 78.
I was just wondering, how would you register your car? As a 78 or a 72
Old Oct 25, 2005 | 08:44 PM
72LS1Vette's Avatar
72LS1Vette
Most likely you would register the car with the VIN # on the body. The serial number is supposed to be stamped on the frame also, but on my frame at least the number is lost to rust pitting. I doubt many DMV people are going to go crawling around under a 30 year old car looking for discrepancies. As long as you have a bill of sale for the new frame you should be fine.
Rick B.
Old Oct 25, 2005 | 09:20 PM
enkeivette's Avatar
enkeivette
Where are the VIN numbers located?
Old Oct 25, 2005 | 09:32 PM
Batsy74's Avatar
Batsy74
Old Oct 25, 2005 | 10:47 PM
dboz's Avatar
dboz
It should work fine. If the last 18 inches of your frame is good you can take some good measurements and just swap that area. Cut the 78 and add on your 72. With some simple patches to match the thickness discrepency no one will ever know if you do it on the top side of the frame. On the horns you will need to drill some new holes for the bumper brackets.
As stated above...the numbers are usually long gone and few inspectors would waste time checking unless something seemed fishy with the paperwork. And if it is already registered then absolutely no problem.
Old Oct 26, 2005 | 09:33 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Try Gee's. He has a lot of frames laying around. Resonably priced too. He is in PA. 570-376-3421
Old Oct 26, 2005 | 11:17 AM
72LS1Vette's Avatar
72LS1Vette
From some recent posts I understand that the VIN is supposed to be located on the top of the frame where it arches over the driver's side wheel. I don't think you could see it without a mirror on an assembled car. I have literally been over every inch of my frame recently and there is no sign of a VIN number. The area above the wheels is not severely rusted but there is enough roughness to have obliterated any numbers that may have been stamped there.
Rick B.
To Frame replacement
