Hood height
Old Oct 25, 2005 | 08:57 PM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
Default Hood height
Hello all,
I've spent most of my time over in C5, but I'm about to get started on my '81 interior restoration. The body's in great shape except for the fact that the hood seems to stick up about a 1/4" in the front.
Is there a way to "bring it down"? Or do I have to shim and raise the front end to meet it? The rear of the hood looks fine....
Thanks for any input.
Here's a pic..
Old Oct 25, 2005 | 09:20 PM
Flying Ace's Avatar
Flying Ace
OK, not everyone at once....
one at a time....
anyone..
Old Oct 25, 2005 | 09:59 PM
Blue 74's Avatar
Blue 74
My 74 has the same problem. Waiting to see what answer you get. The guys here helped me fix the low spots on the hood where it blends into the fenders about half way back the length of the hood. (I didn't have the rubber bumpers) Now if I can pull the left front corner down I'll be set.
Old Oct 25, 2005 | 11:05 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
How is it from the front corners at the fender lines and aft?
Old Oct 25, 2005 | 11:27 PM
rihwoods's Avatar
rihwoods
Look to see if there are shims under hinges..sometimes shims are used to bring hood "up" flush with fenders at hinges/and or strikers/bumpers..you may get lucky,and only have to take some shims out...if i understand your problem...
Old Oct 26, 2005 | 12:39 AM
GDaina's Avatar
GDaina
if there are no shims under the hinges, not much one can do
Old Oct 26, 2005 | 06:59 PM
Flying Ace's Avatar
Flying Ace
Front and front corners are where she sticks up. At the fender lines it's right on and smooth. and aft is only a bit high, barely noticable.
Old Oct 26, 2005 | 07:00 PM
Flying Ace's Avatar
Flying Ace
I'll have to take a good look for that and let you know.
Thanks!
To Hood height
