Timing Help Please
When I rev the car in idle it revs great, but when I drive it on the road and I hit the gas hard it sputters and wants to stall on me. In order to be able to go full throttle I have to slowly ease into it in order to not get this effect. I am unaware if this is a timing problem or a carb problem (or both). The engine is a 355ci and the carb is a Holley DP 700. I very much appreciate all the help/advice people have to offer, I'm still very new at this.
The problem is that you only have centrifugal advance, which is a direct relationship to RPM. This means that your distributor can not sense the load of the car. That is what vacuum advance does, it senses the load according to vacuum and then advances the timing based on that. The only way for you to advance timing is to increase the RPM, which means you have to give it gas and rev it up.
To tell you the truth, I never got my car to run right with only centrifugal advance, but I was able to getting running well by shortening the timing curve (installing the largest bushing), which increased the initial timing and slamming the timing in real early. See, the trick I experienced was, you need to slam the timing in right off idle in order to eliminate the lag associated with engine waiting for the advance curve to start.
For example if your advance starts at 1500 RPM and ends at 3000, then it is going to have the same initial timing up to 1500, which in your case is 15 degrees. That is why I think I got a stumble and why I had to give it gas to get it going from a dead stop.
I tinkered with the SOB for about a year and never got it right. In the end, I felt that I was really close with this setup. By the way, I had a 6AL box, and a MSD distributor, just like yours. (I bet it is the same part.)
This is what I did:
I put in the largest bushing in to shorten the total centrifugal advance to 18. It also increased the initial timing to 18, while keeping the total at 36.
I set the idle speed to 800.
I installed the lightest springs, which started at 800 to 850 and was fully advanced at 1750.
As you can see, I was trying to eliminate the lag between the idle RPM and the starting of the centrifugal advance.
I WAS ABLE TO DO THIS BECAUSE MY ENGINE ALLOWED ME TO. THE LIGHTEST SPRINGS MAY CAUSE DETANATION ON YOUR CAR.
It made the drivability better, but not like vacuum advance. The thing was a rocket when it was fully advanced, but it was really hard to drive. That is why vacuum advance is used on street cars, for the drivability and throttle response. Your setup is more of a drag strip setup where the engine spends most of its time at WOT.
If you want my opinion, which you really didn't ask for, I would say that you can get it to work, but your gas mileage will suck really bad, it will be really jerky (really bad throttle response) and you will spend a lot of time down shifting to keep RPMs up. Basically, my gas pedal was an on/off switch. Also, you will most likely have to tune the carb to compensate.
In the end, I switched to a vacuum advance because the drivability just started to drive me nuts, but once again, give the setup above a shot and see if it helps.
If you need more info on my old setup, shoot me a PM or email at joecalo@gmail.com because I have already cluttered this post with a lengthy response.
Sorry guys!
Thanks,
Joe
It sounds like I should get a new distributor with vacuum advance, hopefully that will solve my problems.
It sounds like I should get a new distributor with vacuum advance, hopefully that will solve my problems.What is the MSD part number. I had part number 8571, which you can not add a vacuum advance unit to, but maybe you can add one to yours. post the part number.
Also, if that does not work, I bet you can get it to run well enough with the right settings.
Start by posting the part number and I will check to see if you can add a unit to it. I just hope it is not 8571.
Thanks,
Joe
Fevre, the distributor was on the car when I got it. I'll check out the shooters tonight to see if there is any lag with the gas.
http://www.msdignition.com/forums/in...t=0#entry17991
Thanks,
Joe
