gas tank questions
Old Oct 26, 2005 | 08:46 PM
hubes's Avatar
hubes
Default gas tank questions
i was thinking an aluminum gas tank would be a good way to lose some weight, so i got to thinkin(probably not a good thing) is there any companies that make aluminum tanks for c3s? would there be any reason to not use an aluminum tank? and just out of curiosity, do the newer vettes have aluminum tanks, and if so, when did they start using them? thanks
Old Oct 26, 2005 | 10:08 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
The 1997 to 2006 Corvettes use a plastic gas tank.
Old Oct 27, 2005 | 01:12 AM
lowbuck72's Avatar
lowbuck72
An empty gas tank, does not weigh very much. Even so, the best place to lose weight would be on the front of the car, not the rear. C3's are already nose heavy. Switching to an aluminum intake would save you more weight, and in the right place.
Old Oct 27, 2005 | 07:39 AM
markdtn's Avatar
markdtn
Rock Valley makes aluminum tanks for street rods and does make one for C3. They can make them with internal fuel pumps for fuel injection conversions too.
Old Oct 27, 2005 | 02:41 PM
Z-man's Avatar
Z-man
After just removing and replacing my tank, it was so light that I think efforts to remove weight would be better spent elsewhere.
Old Oct 27, 2005 | 04:48 PM
sb69coupe's Avatar
sb69coupe
Law of diminishing returns.
Old Oct 27, 2005 | 05:03 PM
73jst4fun's Avatar
73jst4fun
Your much better off loosing the weight in the front, changing the stock intake can loose you a quick 24lbs. 16lbs is an aluminum intake vs. the heavy (40ish lbs). Change the stock rear spring if you want to loose weight in the rear. Go with a composite spring (7-8 lbs)
vs. stock spring at 44-46 lbs., big differance there, but concentrate on the front, heads, water pump, headers....
Old Oct 27, 2005 | 06:58 PM
68/70Vette's Avatar
68/70Vette
Agree the steel tank doesn't weight much plus it might provide a small extra margin of safety in the event of a rear ender.
Old Oct 27, 2005 | 08:04 PM
ETM's Avatar
ETM
Or maybe an aluminum radiator.
Old Oct 28, 2005 | 01:08 PM
flynhi's Avatar
flynhi
Think about
alum radiator
alum heads
ministarter
elect fans
centerline wheels
alum calipers
remove spare tire
lightweight flywheel
headers
more radical
fixed headlights
alum hat rotors
carbon fiber driveshaft, half shafts
see archives for many more.
Old Oct 28, 2005 | 06:09 PM
hubes's Avatar
hubes
thanks for the help, looks like the aluminum gas tank is a waste of money, i know abut all the other stuff, i just thought maybe add the gas tank to the list. so the new vettes have plastic gas tanks, did they have steel ones up til 97? thanks
To gas tank questions
