Carb Popping
Old Oct 27, 2005 | 03:09 AM
enkeivette's Avatar
enkeivette
Default Carb Popping
My Q-Jet pops occasionally when the car is warming up. Doesn't sound like a backfire. What could it be?
Old Oct 27, 2005 | 09:20 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i don't know .....but didn't i hear that carb popping was coming from too lean of a mixture?
Old Oct 27, 2005 | 09:22 AM
Boofers's Avatar
Boofers
A vacuum leak can lean your mixture and cause popping...
This might help you out -
Excellent QJet troubleshooitng by Lars
Old Oct 27, 2005 | 10:22 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
If the pop comes when you step on the gas, your accelerator pump may be bad. To check remove the air cleaner follow the pump linkage to the top driver side of the carb. Push down on the pump shaft and look down the venturi for a strong steady stream of gas into the primaries. Ron B.
Old Oct 27, 2005 | 01:44 PM
enkeivette's Avatar
enkeivette
Accelerator pump? Clue me in...
Also I think you guys might be right. My choke doesn't work so it would make sense that the carb leans out when it's warming up.
Old Oct 27, 2005 | 11:18 PM
bobs77vet's Avatar
bobs77vet
the accelerator pump has a small resorvior of gas in it and works just like an old fashion lever action water pump...except for gas.....when you step on the gas pedal it makes a linkage push a lever and instantaneously squirt gas into the venturis....however i would guess most carbs have diaphrams in them so if that is torn nothing happens.....to check this with the car turned off take off the air cleaner and go to WOT and you should see gas squirting into the carb from a small hole some where.
Old Oct 28, 2005 | 12:25 AM
enkeivette's Avatar
enkeivette
When I yank the throttle linkage I see two squirts of fuel shoot into the carb. But nothing constant, just those short bursts.
Old Oct 28, 2005 | 03:51 AM
madmike's Avatar
madmike
carb popping is when the vehicle gas air mixture is too lean. Sounds like you get a good squirt from the accelerator pump just sounds like your not choking enough till the vehicle warms up. Id say fix the choke and the problem is solved..
Old Oct 28, 2005 | 08:19 PM
enkeivette's Avatar
enkeivette
You must be right, my Q-Jet doesn't work with the new intake manifold. But is the poping dangerous? I am saving up for a Demon but the Mighty Demon 750 that I plan on buying doesn't have a choke at all.
Old Oct 28, 2005 | 08:42 PM
comp's Avatar
comp
To Carb Popping
