I have about $1000 to spend on aluminum heads for my 383. I currently have 64cc camell humps that are slightly ported, they have been milled twice so may be around 58cc, my compression is about 10.75 to 1. I have heard a lot about edelbrock heads. this is strictly street driven. I currently have a performer manifold with a 770 avenger carb, headers and true 2 1/2 duals. the car runs great but you allways want more. I wa told it would possibly add 50 to 75 hp, is this true? I know it will help with detonation. I have to run 93 with booster now to stop detonation. what difference does runner length make?
64cc (or higher) chamber heads will bring that 10:75 compression down to pump gas compatability and probably rid you of detonation. Runner length controls flow...too large can drown your engine makeing it difficult to idel/tune well...too small and the motor won't reach potential. That's a simple explaination....I can't get any more technical than that...
Experts will probably chime in and explain more throughly..
Eddie
I was just quoted on the newest Australian ProComp heads from a speed shop in TN. I had purchased a lite weight starter from him on Ebay and it was a heck of a deal and looks great so asked about a few other items.
This is cut from the email I was sent about the heads:
They will cost around $950.00 fully dressed out, with roller rockers, and stud girdles, stainless valves, etc. They are ready to bolt on. The runners are 200 cc, and the chambers are 64 cc. The valves are 202, 160
I will probably try a set, but have to get them with 72CC as I do not have flat top pistons.
I talked to the guy for a good 1/2 hour on the phone after that. He also builds 383 stroker motors complete for about $3,200 with these heads. He says that they would be a true 410-415 HP.with the components he installs, but I have no other details on the motors.
it's very possible. I picked up 70rwhp on my 355 from a head and intake swap. This was after switching from the 170cc S/R torquers to a pair of 195cc trick flows. Your 383 will like a better flowing head.
www.treperformance.com has 180 & 195 runner AFR .. choice of 68cc or 74cc chambers ... assembled w/ springs, valves, seals, retainers locks, studs, guideplates ... price per PAIR is $1285 and that INCLUDES DELIVERY.
I didn't see anything that says the price is per anything. Each or pair, set whatever.
Just a price per kit which that don't say what a kit is if its a set or pair or an assembled single head.
Oh- the BB heads seem affordable so if they are eachs they want gold in exchange for them.
I have emailed w/ treperf .. $ is per pair. Also, I have '05 afr cat & racer net price sheet ... there, it is clearly shown same heads are priced per pair at $1324 (racer net) and that does NOT include delivery.
In reality, BBC afr are ABOUT $1000 MORE per PAIR than a similarly cnc'd & assembled sbc afr. Regardless which brand ... BBC head prices are similarly higher$ than sbc. Just part of why BBC typically cost more to build than sbc.
So ... seems the DELIVERED $ difference between sbc RPM & sbc AFR is that AFR ABOUT Thirty per-cent or $300 more.
Are these the "original" design of AFR, or the new one? I was looking at getting a set of Al heads early this year & narrowed the choice down to either AFR180 or Trick Flow 23 deg heads. At the time there was a lot of talk on the forum about AFR heads burning oil, etc, long story short, I've got an email from AFR (somewhere) saying that they were bringing out a new design of head in late summer/fall which I guess would be around about now. Could be that this new (& improved) head is about to hit the market so there could be some old stock of the previous design about to get off-loaded at good prices? Maybe.
I haven't looked at heads for a while (not since ordering both types of head failed to get either delivered ) so maybe the new AFRs are already on sale? If not, trawl the archives for comments on AFR heads before you decide.
Measure your ride height at the front with the current heads as the front may lift up slightly if you fit lighter Al ones.
p.s. good luck with whatever you decide - hope you get better luck in actually being able to buy some than I did!
what about theese for my 383? Edelbrock Performer RPM
here are the specs
170cc intake ports and 60cc exhaust ports. These heads feature 2.020'' intake and 1.600'' exhaust valves and 1.460'' valve springs that allow a .575'' maximum lift.
here are the specs
170cc runners will hold you back. 180 to 195 runners will work better with the cubic inches & 480 lift 230 dur Lunati bracket master your running.
Just my opinoin...
Eddie
