Installation advise - New Shocks
Old Oct 29, 2005 | 10:14 AM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Default Installation advise - New Shocks
After much back and forth on Koni vs. Bilstein, I ordered new koni shocks for my 72 BB coupe.
Reason: My brother had a set of Koni's for almost 20 years and they still work great.
I was looking for any pointers on the installation, it seems to be straight forward like any other GM chassis that I have done in the past but I'd hate to be caught with something that keps me of the road longer than needed.
Thanks.
Old Oct 29, 2005 | 10:26 AM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Front are no brainers. Compress the shocks then put them in. Have a helper keep it compressed if possible so you are not fighting the shock as you do the lower bolts.
Rears - be careful with the shock mount. A bi-otch to get the shock off the mount as the rubber seems to bind. DO NOT Beat with a hammer. New shock mounts are $45 a piece. There is a tool to beat on the shock mount. Most corvette venders sell it. Basically a blind nut that you hit and it save the threads.
Cheers,
Pete
Old Oct 29, 2005 | 10:36 AM
danthony's Avatar
danthony
Great. The rears were my concern!
Thanx
Old Oct 29, 2005 | 10:48 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
If your shock mounts have not been out in a while (years) it's very likely that the strut rod's inner sleeve is rusted to the shock mount. Look at the drawings in one of the many books - if that sleeve is rusted to the mount there's almost no chance that you get it loose. Penetrating oil does not get where you need it, no matter how long you let it soak
Excessive beating on the shock mount can damage (crack) the spindle housing, the two "arms" that the shock mount mounts to are not very thick... be careful...
If it doesn't come loose you may want to consider cutting the strut rod end with a Dremel, new strut rods are always a good idea on old cars and they are a lot cheaper than shock mounts or a spindle housing.... just my 2c...
Old Oct 29, 2005 | 11:06 AM
SteveG75's Avatar
SteveG75
Shockmounts do not have to be removed to install rear shocks. They do have to be removed to install strut rods but the shocks go on the end of the mount. Easy job.
Old Oct 29, 2005 | 11:09 AM
mandm1200's Avatar
mandm1200
There's no need to remove the shock mount for the rear. He is changing shocks, not strut bushings.
Old Oct 29, 2005 | 12:15 PM
danthony's Avatar
danthony
Thanks again, I am not removing the strut rods, just shocks.
Old Oct 29, 2005 | 02:34 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I only had half a cup of coffee when I replied.... what was I thinking ? Was I thinking ????
To Installation advise - New Shocks
