1968 Body Panel sag
Old Oct 29, 2005 | 06:44 PM
1968vertcop's Avatar
1968vertcop
Default 1968 Body Panel sag
HELP!!!!!! I have got two panels on my convertible that are not lining up right. The front clip was missing brackets inside the nos epice and the hood and surround was not ligning up. On the back the top storage door and rear and not ligning up. Anyone have any suggestions.
Old Oct 29, 2005 | 09:19 PM
TOM B1's Avatar
TOM B1
I restored a 68 a few years back so here is my thoughts. The front surround is supported by a piece of steel that gores behind the headlights to the front lip of the hood seam. This steel piece is BONDED to the the fiberglass and comes loose offen as the factory bond was not to good on a 68. Use Vette panel bond as I did to repair this. A support is needed to hold the new bond and to take out the sag til it drys. The rear problem can be a cracked inner support panel that cam unbonded. Most that I have seen a on the Quarters in or near the wheel well. Also check the rear body mounts for missing mounts or shims or even smashed or broken fiberglass where the mount sets.
Old Oct 29, 2005 | 09:34 PM
big_G's Avatar
big_G
The front header is a weak point on the '68. The remedy came out in '69-up with the addition of end support brackets that attach to each inner fender-well and support the header bar. You can get these parts from any 'Vette parts catalog. The rear view of your 'Vette shows to have been hit. The peak at the spoiler center is too pronounced. That is evidence of a collision. I would look for a bent frame and/or body-work issues..G/L
Old Oct 30, 2005 | 03:17 AM
Twin_Turbo's Avatar
Twin_Turbo
Seems to me your header bar is either loose or rotted out, if it is, the nose will sag in the middle.
Old Oct 30, 2005 | 05:16 AM
1968vertcop
yes I have the brackets in place in the front nose, those that are pictured. i am wondering if there is a way to adjust them to brind the driver side a little higher. As for the back, frame is straight, but i think the passenger side may be missing some sort of a body mount making it sag similar to the front. Anyways thanks for the info so far.
Old Oct 30, 2005 | 05:18 AM
1968vertcop
in the second pic I am trying to get the passenger side of the "trunk" lid to sit farther down, that may not be a good picture to demonstrate with.
Old Oct 30, 2005 | 05:58 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
On the passengers side decklid, loosen both bolts. Put a washer or two under the forward-most bolt. Tighten things up and try it.
By doing this, you're "cocking" the hinge, which should allow the hinge to come down a bit more, which will allow the rear of the decklid to come down more.
It doesn't make sense, ADDING a shim or two, but it works.
Same trick works for aligning a hood, but your pic looks like you have other issues, as others have said.
Chuck
Old Oct 30, 2005 | 09:15 PM
LemansBlue68's Avatar
LemansBlue68
Another adjustment that may be of interest for the nose sag is an L shaped bracket that attaches near the very point of the the nose to the steel support that attaches to the very front of the surround. This bracket is slotted and attaches to a bracket welded to the "horseshoe" that is bolted to the bolt-on crossmember at the front frame horns. This bracket can be moved up and down to raise the nose slightly and the bolt retightened. I don't think this bracket was used on late '68's or subsequent years. A support rod was used in its place later in production that attached to the center of the radiator support near the bottom.
Big G and Chuck G also have offered good advice too, as I have used both of these tricks when restoring my '68.
Old Oct 31, 2005 | 08:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by big_G
...The remedy came out in '69-up with the addition of end support brackets that attach to each inner fender-well and support the header bar....
I added the '69 pieces (L & R) to my '68 and it stiffened things up considerably. On the deck lid, check to see if you have an unnecessary shim on the spring on the passenger's side.
Old Nov 1, 2005 | 03:16 PM
1968vertcop
Thank you for all your help. A sepcial thanks to the guy that told me to add a washer on the front bolt of the deck lid. Worked wonders, don't really understand how, but it worked. I do have one question on the front. I have the brackets pictured already in place. Is there supposed to be a bolt in the top of them? It looks like there is a place for it, even in the picture, but they are not in place. I need to make an adjustment to them, either by adding a shim, or adjusting bolts, but there is no bolts. You can see in the pic that someone posted there are bolts shown on the side but not on the top. Just curious if that is how it is supposed to be. It kinda makes since because if you have a long bolt it would go right through the front nose clip. Thanks again
Old Nov 1, 2005 | 04:03 PM
Chuck Gongloff
A sepcial thanks to the guy that told me to add a washer on the front bolt of the deck lid. Worked wonders, don't really understand how, but it worked. Thanks again
That's an "old indian trick". Works on hoods too if the hood is too high in the front in relationship to the body. Chuck
Old Nov 1, 2005 | 04:36 PM
big_G's Avatar
big_G
The '68 header bar doesn't have a hole to put a bolt like the '69 and up. Use a 5/16x3/4 in. sheet-metal bolt. You will need to drill a starter hole first. You may need a right-angle drill to do this. It's gonna be a bear to move the surround much. Get it as flush with the hood as you can If it needs more lift, it's body-work time. There are good fillers for fiberglass available that won't shrink like bondo.
To 1968 Body Panel sag
