Back together and running
Old Oct 30, 2005 | 10:20 PM
vettepilot68's Avatar
vettepilot68
Default Back together and running
ahh, yes! she back together and running
After having the engine out and replacing the cam and several other pieces and parts...going through the tranny etc, I got it all back together tonight and fired it up. After a couple of "challenges" with the ps pump leaking and fan blade scraping the shroud, I ran through the break in on the cam and all seems to be well.
I want to thank a few members personally for the help...JCGD3...couldnt have been a success without you...Lars...the paper on the distributor install was awesome...I followed the directions to the T and the timing was near perfect from intial firing...thanks for noticing that I had a 68 and sending me the additional data for the 68 variance on the dist cap setup.
Now hopefully I can enjoy it for a bit!
I have some pics of the final project, but need to pull them off the camera. Stay tuned!
Old Oct 30, 2005 | 11:38 PM
Jclgodale3's Avatar
Jclgodale3
helps what it's all about partner
Old Oct 31, 2005 | 12:12 PM
steves_77vette's Avatar
steves_77vette
What's your new setup? And any opinions based on "seat of the pants" performance?
Old Oct 31, 2005 | 05:25 PM
vettepilot68
The new set up is bone stock...however, it is the L79 option, so it does still have a little more lope than the norm...
I took out a comp cam (292h) and replaced it with the stock cam (similar to comp cam 151h but I didnt buy from CC)...the difference is really felt in the low end...which is what I was looking for...I like it better for daily driving...and a bit more vacuum for the vac operated stuff. The previous cam was like a rocket once you got over 1500 rpm's, but not so good getting to 1500 or so...big difference in early responsiveness.
Old Oct 31, 2005 | 07:34 PM
Jclgodale3's Avatar
Jclgodale3
WTF? post sum pics!
To Back together and running
