TH400 Shifting problems
My TH400 is shifting early and very soft and won't downshift under heavy throttle. I am going to replace the modulator, but I also have discovered that I do not have a kickdown switch. It is supposed to be mounted to the carbuerator linkage somewhere, but I can't find any diagrams or pictures. I would assume that it is the same setup as a Corvette would have. Does anyone have any idea how to hook one up?
Thanks.
ISBN 0-87938-267-8
I reccomend this book highly!!
"Where is it?
The downshift linkage adjustment is made at the detent or detent/stator switch. Since the 400 was first introduced in 1964, numerous switch types and switch locations have been used.
Most often the switch is located at the carburetor throttle lever, or under the instrument panel, above the accelorator pedal."
My bet is that the detent switch is above the accelorator pedal on your car. Either it has failed, is out of adjustment, or has been disconnected.
