Gauges Died
Old Oct 31, 2005 | 10:28 PM
kansas's Avatar
kansas
3rd Gear
Default Gauges Died
My gauges died and the fuse in the slot marked gauges on the fuse block is good. Any one got an idea on this problem.
Old Oct 31, 2005 | 10:42 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
I just fixed mine yesterday on my '82, it was the wire harness connector on the back of the center cluster, it came loose so I pulled the cluster out and made sure all the contacts were straight, changed a couple burned out bulbs while I was in there, plugged the harness back in and put her all back together and everything works fine. Once you take out all the screws you gotta carefully turn and angle the cluster away from the dash. Disconnect the battery first or else you'll blow the gauges fuse. . .ask me how I know
Old Nov 1, 2005 | 09:43 AM
jdp6000's Avatar
jdp6000
I'm with Fred....
Also don't forget the two screws that hold the center cluster to the console...they are underneath. You need to remove the side panels to get at them....ask me how I know....
Jim
Old Nov 1, 2005 | 11:51 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Originally Posted by jdp6000
I'm with Fred....
Jim
Thanks Jim, I forgot to mention the 2 bottom screws.
Old Nov 1, 2005 | 07:45 PM
kansas's Avatar
kansas
3rd Gear
Thank you for advice, I will try it this weekend
Old Nov 1, 2005 | 10:44 PM
79 Bullet's Avatar
79 Bullet
here's a pic. you can slip your hand in from the passenger side up and feel your way up there and try to make sure the harness is plugged in. At least I could on my 79.
[IMG][/IMG]
To Gauges Died
