Did we do the right thing?
Old Nov 1, 2005 | 04:37 PM
Demonic Possession's Avatar
Demonic Possession
Default Did we do the right thing?
Hi,
I'm new to this board. I have an 1975 base stingray with 20,053 originial miles. One problem, it hasn't been started in 20 years. Me and my dad finially got around to working on it at the end of summer. So far, were taking the engine apart. Were going to try to get more than 165 hp from it If anyone is interested in viewing what we've done so far, justClick Here Anyways, back to my question. This car hasn't been started in 20 years. Pretty much, 20 years ago, it was putted in the garage and left there. It included originial, 80's gas, oil, fluids, tires, ect(PM if you are interested in any of these truely rare automotive collectables from the 1980's ). I was thinking about it today and I was curious if it would have started if we replaced all the fluids and putted in new battery, sparkplugs, ect. What do you guys think?
Thanks,
Max
Old Nov 1, 2005 | 04:40 PM
joe73vette's Avatar
joe73vette
50-50, if the motor was in a damp environment, it could have rusted internally in all that time and stuck. If it turns over, you probably could have started it. But then it would still have 165 hp. Too late now, have fun and don't forget to go through all the other systems, too. Joe
Old Nov 1, 2005 | 04:43 PM
69monzaredbigblock's Avatar
69monzaredbigblock
20 year old mice now homeless....... what a shame.
Old Nov 1, 2005 | 04:45 PM
Demonic Possession
I know, it's truely sad.
Old Nov 1, 2005 | 04:46 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
You are in the right place to talk about doing the wrong thing
Meaning, We are a bunch of hot rodders here, so we support your decision! At least I do
Demonic Possession
That's what we were thinking, but the piston walls weren't as bad as we though they were going to be. Oh, taking apart the engine now gives me an "excuse" to upgrade.
Old Nov 1, 2005 | 04:49 PM
Demonic Possession
This sounds like my kind of place. I was thinking about putting in a newer corvette engine...possibly a 98. We just need to see how much everything is going to cost. If I can't afford a new engine, I guess I'll go with a honda civic engine, so I can be crazy fast!
Old Nov 1, 2005 | 04:53 PM
panchop's Avatar
panchop
i picked up a 75 vette also that i am doing some mods on to make more power. keep us informed.
Old Nov 1, 2005 | 04:54 PM
427V8's Avatar
427V8
I would SERIOUSLY look at an LS1, LT1 whatever they are that came in Camaros etc. They can make wicked HP, are light and fuel injected.
I built a 434 small block Click the chick to see my web page
Old Nov 1, 2005 | 05:04 PM
Demonic Possession
Thanks for the tip. A friend of mine has been telling me that I should put an LS1 in it. I have all winter to research and decide
427V8, nice small block. How much did all that run you? How many horses does it have?
Old Nov 1, 2005 | 05:07 PM
Demonic Possession
Actually mine does have some mods on it. I have it written down somewhere but I know for a fact that it has different gears(not sure what kind) and it has some "new" racing heads waiting(for 20 years) to be installed.
Old Nov 1, 2005 | 05:13 PM
427V8's Avatar
427V8
I built it back in like '99, for $8k I think parts cost I reused nothing but the block.
I wussed out on the cam, moderate lift about .500 so I got 460 out of it on the dyno but it made over 400 ft/lbs from 2800rpm to 6000rpm with a peak of 500 something.
I keep threatening to put in a bigger cam, like .650" lift and get 600 horses out of it, but there is always something else to do!
It's a fun engine, but I think a strong LS1 would be better.
Old Nov 1, 2005 | 05:45 PM
Demonic Possession
**** it's got some nice horses on it. You should wait a while to put in a different cam, that way, you can play around with it at 460 and then get 600...like a new car. I'm guessing you had to change the suspention and things like that. Or maybe not. How many horses can a stock '75 vette. Now that I think about it, your probably had to.
Old Nov 1, 2005 | 08:53 PM
427V8's Avatar
427V8
Well I did rebuild the entire suspension front and rear, went with an LT1 3.70 diff. But I didn't do anything special to make it stronger. Still using the small 1/2 shafts too.
Mine's a '69 but the 75 still had the iron diff so it should be good to 750 HP or so.
And wait a while? I've been driving it for 6 years already
Old Nov 1, 2005 | 09:25 PM
enkeivette's Avatar
enkeivette
Cough cough 20 years of tar and rust... yummy.
The engine probably would have siezed up anyways. Good thing you're rebuilding it. Take your time, and spend all your money. Do it right the first time.
Old Nov 1, 2005 | 10:56 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Looks like there's some rust on the cylinder walls, the anti freeze looks good though... still green after so many years
I assume you're going to replace the cam, lifters and pushrods ? If you're going to re-use the old parts you better label them so you put them back in the old location.
nice car
Old Nov 2, 2005 | 12:25 AM
GDaina's Avatar
GDaina
I doubt very much if you have any rust on the cylinder walls...if anything maybe in the fuel and brake lines. Engines will keep ages if the plugs are in and carb is closed. Me tinks you could have saved yourself a ton of work and $$$ by just replacing the fuel and brake lines, if they needed replacing.
Only thing you had to do was prime the engine with fresh oil, put the gas in the tank, change the plugs and turn the key.
To Did we do the right thing?
Old Nov 2, 2005 | 04:23 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Originally Posted by RedBad1979
One of my favorite tools, a crowbar.
Keep us updated with progress & pictures.
Old Nov 2, 2005 | 09:38 AM
Jims79's Avatar
Jims79
I don't think you should be showing this young man your 69 with the half dressed girl next to it.
But could you send the rest of us full size shots of both.
Old Nov 2, 2005 | 09:48 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...just my opinion, I would have pulled the original motor without taking it apart to preserve it and put in another motor. Last year I bought a GM '73-'85 Direct Replacement 260hp/350ci 4 bolt main for $1187 off of the Internet for my 1975 Corvette. I'm more of a "cruiser" than a "racer", so this motor is more than adequate for me. I've put over 6K miles on it this past summer and it's performed perfectly. In also doing that swap, I changed my '75 over to a 4spd car. The original L-82/Turbo 400 is neatly tucked away off to the side while I enjoy the new motor & 4spd.
