Divorced choke - electric conversion
Old Nov 4, 2005 | 02:06 PM
rcread's Avatar
rcread
Default Divorced choke - electric conversion
I have a divorced choke on my QJet. I'm installing L98 heads, which don't have a heat crossover, so I am trying to figure out the choke situation. I found an electric conversion for a divorced choke (see link, item # CU445). Has anyone used one of these before? It bolts to the intake, seems like a simple solution that might work.
Here's the link
Old Nov 5, 2005 | 07:39 AM
theandies's Avatar
theandies
I have that on my ZZ4. It works good but you do have to be creative when you install it. The stock choke rod will have to be shortened and bent just right to make it close the choke plates.
