Angle Mill vs. Flat Mill: Piston to valve question-->
Old Nov 6, 2005 | 12:00 PM
68 Yellow 468's Avatar
68 Yellow 468
Default Angle Mill vs. Flat Mill: Piston to valve question-->
If you had a head with a 110cc chamber that had been flat milled to that volume and had no piston to valve interference, could you make a leap of faith and say that a head with the same 110cc chamber that had been ANGLE MILLED to that cc would also have NO piston to valve interference???
Thanks in advance to the gurus.
Bryan
Old Nov 6, 2005 | 12:31 PM
45ACP's Avatar
45ACP
Originally Posted by 300ZXTwinTurbo
...could you make a leap of faith...
No. Never. Either from experience, careful calculations or test fitting you must KNOW that there is no interference before lighting her off.
Old Nov 6, 2005 | 12:43 PM
C3 Stroker's Avatar
C3 Stroker
ANY milling yields less clearance......from knowledge or test fitting, be certain.
Old Nov 6, 2005 | 02:23 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would not put a performace engine together without checking the piston to valve and piston to head clearance
Old Nov 6, 2005 | 02:50 PM
David Ey's Avatar
David Ey
Don't forget about the different angles of the intake surfaces created when this is done.
Old Nov 6, 2005 | 03:46 PM
68 Yellow 468
No doubt I appreciate all of the words of caution in terms of checking / measuring; that is something that my machine shop will no doubt do.
I suppose the real information I was looking to gather had to do with how the valves sit relative to the piston and how that relationship changes when you choose to angle/flat mill a head.
In other words, which choice of milling would cause you to run into interference with a piston more readily?
Anyone have that answer?
Thanks.
Bryan
Old Nov 6, 2005 | 04:37 PM
C3 Stroker's Avatar
C3 Stroker
Thanks.
Bryan
Good question.......when I got my heads from AFR, I requested them milled to 64cc chambers (down from 68cc). They flat milled them. They said this would be more desireable than angle milling. More metal would have to be removed per cc to achieve the same volume (.008" per cc for angle vs. .006" per cc for flat for my 195's). I didn't inquire further, but I suspect the valve angle might bring it closer to the piston (engine gurus, correct me if wrong, please).
Old Nov 6, 2005 | 05:45 PM
pauvil's Avatar
pauvil
I know from experience with pistons at .240 dome (in bbc's) that when you start getting around .520" lift it's close and you start to check, if your using .100" domes or less you can get more without worry. Watch your valve springs... not enough pressure will send them into the piston at high rev's.
Old Nov 6, 2005 | 08:02 PM
comp's Avatar
comp
Bryan
what heads ???
Old Nov 6, 2005 | 08:12 PM
norvalwilhelm's Avatar
norvalwilhelm
Angle milling rolls the head over slights, It changes slightly the angle at which the valve strikes the piston, well we hope it doesn't hit but the angle changes so the chances of the upper corner stricking the piston are greater but it increases flow more then flat milling.
The intake becomes a problem and the head/intake surfaces need to be changed along with the head bolt holes.
Rolling the head over changes the hole through the head for the head bolts. Too much angle mill and the bolt holes need to be opened up.
Also the bolt holes need to be spot faced to straighten up the bolt hole for the head of the bolt to rest flat on the head.
To Angle Mill vs. Flat Mill: Piston to valve question-->
