Temperature sending unit question
Old Nov 6, 2005 | 11:09 PM
Shocker's Avatar
Shocker
Default Temperature sending unit question
I recently replaced the temperature sending unit on my '69 after determining it was faulty. However, I now get an excessively high temperature reading (250) with the car at idle. Everything else was working perfect beforehand. Before installing the new sending unit, I read that one should not apply any type of sealer to the threads, since that will affect the gauge reading accurately. My brother insisted on sealing the threads to prevent any leaks. Could this be the cause of my faulty gauge readings now? Thanks in advance for any helpful suggestions.
Old Nov 6, 2005 | 11:12 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
It could be making a poor electrical connection causing a higher resistance and bad reading.
its possible.
Old Nov 6, 2005 | 11:32 PM
Civis's Avatar
Civis
its possible.
Thread sealer can do that to you on these sending units (which is why the manuals tell you not to use any - and that goes for thread tape as well). Metal to metal.
Old Nov 7, 2005 | 01:31 AM
AndreG's Avatar
AndreG
A generic sending unit from a parts store will read high as you are seeing. They are not designed any longer to work within the correct range for our original temperature guages. You will have to buy one from "Lectric limited" or some other supplier that sells senders specifically callibrated for the old style guage sets. Thread sealer may not be helping but is probably not the primary issue.
Good luck
-Andre
Old Nov 7, 2005 | 05:49 AM
djgrelli's Avatar
djgrelli
I agree with AngreaG. When I installed my Vortec Heads I put in a sending unit from a local parts store and it ran at 250+ all the time. Called Lectric Limited and bought the right sender and all is well. I had to intstll it in the thermostat housing becasuse it was a larger thread but it worked. I also agree that you don't need thread sealant or antiseize. The metal to metal is your ground connection.
Old Nov 7, 2005 | 07:16 AM
pws69's Avatar
pws69
Teflon tape will definately cause problems and should never be used on sending units. Regular [plumbers type - non-teflon] thread sealant (I use Rectorseal because my brother is in the business!) should not cause eny problems. I have used it for years without any issues. You should use something 1) to seal 2) because of the different metals involved.
Old Nov 7, 2005 | 08:13 PM
C3 Stroker's Avatar
C3 Stroker
Good luck
-Andre
Same thing happened to me.......I bought the CORRECT sender from Clocks by Roger and all is well. Thread sealer won't affect readings if not excessively used.
Old Nov 7, 2005 | 11:04 PM
Shocker's Avatar
Shocker
Thanks for all your suggestions. I'll try a different sender and let you know what happens.
Old Nov 12, 2005 | 10:30 PM
Shocker's Avatar
Shocker
I put in new sending unit today from lectric limited (had to use different connecting terminal) and applied small amount of thread sealing tape. Unit seems to be working fine in early trials. Thanks for all who helped with my problem.
To Temperature sending unit question
