Help removing valve springs on workbench
Old Nov 8, 2005 | 11:25 AM
Dick72LT1's Avatar
Dick72LT1
Default Help removing valve springs on workbench
I had my engine rebuilt recently and I installed correct heads. Previous owner installed after-market angle plug heads and I’m moving my car back towards stock. I’d like to try selling the heads so I’m trying to remove the old valves and springs. I bought a basic spring compressor, but as I compress the spring on my workbench, the valve moves as well preventing me from removing the retainer. All the reference books I have describe how to do it on the car with compressed air in the cylinder. What’s the secret for removing springs and retainers on the workbench? BTW, the engine was a pretty serious race engine with double springs. Might that require a more serious retainer? I’m over my head at this point. Any help greatly appreciated.
Dick
Old Nov 8, 2005 | 11:39 AM
kona's Avatar
kona
The compressor I use is really old and looks like a huge C-clamp. The bottom goes under the valve and the fork tightens the spring down so you can remove the retainer.
Kona
Old Nov 8, 2005 | 11:52 AM
gerry72's Avatar
gerry72
You can do this with a socket, hammer, and a small piece of wood. Put the wood in the chamber to limit the travel of the valves. Put a socket with an ID slightly smaller than the retainers OD and smack it with the hammer enough to compress the spring at least half way down. The locks will usually fall out after one or two smacks and voila! If it takes you more than ten minutes to do all 16 valves, then you're taking too many beer breaks.
It should go without saying that this technique only works for taking valves out. For installing them, you'll need a proper compressor.
No sheet, this is how I've done it for...well, let's just say that I have years of experience with this method. Taught to me by a very old mechanic when I was a young lad.
Old Nov 8, 2005 | 12:56 PM
MILO's Avatar
MILO
Socket Wood and Hammer. Works every time.
Old Nov 8, 2005 | 01:05 PM
Dick72LT1's Avatar
Dick72LT1
Thanks for the help. I knew there had to be an "old wives remedy". I can't wait to get home to try it. This is what I love about this forum...
Dick
Old Nov 8, 2005 | 05:59 PM
moosie982's Avatar
moosie982
yep,,, always worked for me too, thank God for Alabama Ed and the Greenbush Garage, best school I ever attended Peace,,,Moosie
Old Nov 8, 2005 | 06:14 PM
Civis's Avatar
Civis
Kona
That sounds like the one I have (bought it from Sears for around 20 bucks). Works surprisingly well.
Old Nov 8, 2005 | 06:31 PM
pauvil's Avatar
pauvil
If you have the C-clamp type, wack the valve spring hard with a rubber mallet, this will loosen the locks so the tool compresses easy,a good magnet works to pull out the locks, and of course...I've used the other method plenty of times, amoung other things...
To Help removing valve springs on workbench
