Need some advice. I am installing a 383 425hp/465torque small block in my '69 coupe this winter (preserving the original 350) and need some advice on the following:
1. Recommended accessory drive including a/c.
2. Recommendation on intake manifold that will fit below L88 hood with a
a Demon 750 carb.
3. Recommendation on stainless exhaust header with a four inch collector.
4. Recommended four inch stainless side pipes (street use). Note: I've been told that Hooker muffler inserts are difficult to insert/remove; any other ideas?
Would appreciate suggestions on any part of these issues. Thanks.
