Cam for my 396 small block
Old Nov 10, 2005 | 11:27 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
DD put me a few ponies short of 600HP. Everythiing I tried to do building this motor has turned out right on the money for a change
I am thinking of taking the motor to a engine dyno near me this winter to find out exactly what it puts out
Old Nov 11, 2005 | 08:34 AM
norvalwilhelm's Avatar
norvalwilhelm
And what do you mean alloy heads effectively lower compression? What kind of alloy? For the moment I'll assume that you're talking about aluminum in which case I don't agree. I've heard that aluminum heads can effectively lower CPR at most half a point with advantages that far outweigh this, but a full point?! Sounds like someone has aluminum head envy.
If you have 2 identical shaped heads, one from cast iron and one from aluminum they will have the same compression ratio but the iron head will produce more horsepower because it retains heat. To equal the horsepower of the cast iron head the aluminum head needs to be run one point in compression higher to make up for the lost horsepower.
Old Nov 11, 2005 | 07:03 PM
GOSFAST's Avatar
GOSFAST
Thank You, Gary in N.Y.
P.S. Many years ago, my friend Bill Mitchell (World Products) started the "original" Dart program with cast iron heads. We would sit and talk and we all realized in an "apples-to-apples" situation iron heads always made more power. This was his reason for going the iron route at the time. I just posted on another site a recent test where we took all the components out of a 400" SB (G.M. casting) and placed them in a Dart SB casting. Due to the density of the Dart block, at least this is what we believe, we picked up 18 HP. It's exactly opposite with alloy blocks, we've also tested this, they are able to "consume" up to 40 HP on a race unit. This is all facts. Thanks again, Gary.
Old Nov 12, 2005 | 06:41 AM
enkeivette's Avatar
enkeivette
Well I'm sure, but with aluminum heads (alloy only means two different metals combined not necessarily aluminum) you can run higher compression and much more timing without detonation. It mooore than makes up for any losses. Why do you think all of the best engines you see today have aluminum heads?
Old Nov 18, 2005 | 10:32 AM
lvrpool32's Avatar
lvrpool32
Just as an FYI, recieved the kit today and the KB (or silvo-lite) pistons are actually flat tops with notches for the valves, there not domed)
I also went with a custom small base circle, solid roller from Comp cams.
Nick
Old Nov 18, 2005 | 12:12 PM
gkull's Avatar
gkull
What base circle do they claim as small today, because I had real problems with them in the past.
