Balancing Q's
Thanks everyone!
With the exception of some very low production high performance optioned engines, factory balancing was a ball park thing. The degree of factory balancing was determined primarily by what the maximum rpm the engine was expected to run at. Most engine builders will want to balance an engine to a much lower variation in component weights. They’re trying to minimize the amount of parasitic horsepower lost to the engine. It won’t necessarily increase overall horsepower, but it will make more of that produced, available to your rear wheels.
Most of us will not be able to actually feel a difference, vibration wise, in the balance of an engine. After all, the factory didn’t ordinarily do that bad a job. But what you might feel is that the engine now revs more freely and it will surely survive an over-rev it might not have survived before.
While it may not have the bling of a polished intake manifold or a show quality paint job, the peace of mind it can give you is well worth the cost. I believe that balancing an engine assembly is one of the best values out there for making horsepower you can live with.
GUSTO
Use standard chamfer bearings, nothing fancy. Chamfered bearings are only required for custom ground cranks with larger than stock fillet radius ground into them. That is the only reason to use them. The larger fillet radius ground into the crank will add some strength but not many of us regularly break crankshafts.
If you want to spin it or if you can afford the cost of the balancing, do it.
-Mark.
Here's another question....while I'm going to the machine shop....should I just go ahead and jump into a 383? I'm trying to use the new parts I already have..... but would entertain buying another crank and having the machine work done. But....will the pistons I already have work in a 383? I've got Speed Pro L2256F. If I recall, I can use 350 rods and pistons on the 400 crank.
See how I think!
